Question about BenQ FP791 17" LCD Monitor
Benq lcd FP 791 Displays only white
I have a BenQ FP791 17 in LCD. I was working until one day I turned it on and it now only displays an all white screen. I plugged it in to another computer, same problem. I can add it as a second monitor to windows but all it displays is white. Windows finds it and the mouse can move over to it but I do not see anything. I am handy with a soldering iron, but not nessisarily diagnosing electronic problems. Any suggestions. My monitor screen is white
viziks
  • 220 Answers
SOURCE: Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Posted on Mar 24, 2008
SOURCE: BenQ FP731 Screen briefly displays then turns off
Did an independent diagnosis before finding this, and came to same conclusion. First found fuse PF751 was open circuit (3A black plastic fuse, not glass) over close to main heat sinks. When I replaced that with a fine fine strand of wire (for testing) then I saw Q759 (C5707) get hot. Checking the others shows that they should be driving into about 420 ohms on the primary side of the transformer for the flourescent lights (backlights) but on this one it was less than 1ohm. I've unsoldered the Q759 and now I measure 420ohms here too. Now I need to find a new C5707 or equivalent...
Posted on May 17, 2008
SOURCE: Benq lcd Displays only white
I have a acer al1711 with same problem can i do something?
Let me know write on my msn address masmaster@hotmail.it
Thanks
Posted on Oct 25, 2008
  • 732 Answers
SOURCE: Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Posted on Apr 11, 2010
Es187
  • 71 Answers
SOURCE: trying to purchase a power
On the screen itself, where it plugs in, it should give you a voltage rating, and a line with a C encompassing a circle. Make sure that these two things match up between the two screens, they should, but at the same time, there is the possibility that they don't. Also, make sure the plug is the right size. Yes, it should work, but I would just take the extra precautions listed above to prevent frying your monitor.
I hope this helps!
Posted on May 04, 2011
Benq lcd monitor
The monitor requires an input before it can decide what the input is.
Nov 05, 2013 | Computers & Internet
Trying to purchase a power adaptor for benq fp781 can only find one compatable for fp 791 would this work on a fp 781 monitor ??
I hope this helps!
May 04, 2011 | BenQ FP781 17 in. Flat Panel LCD Monitor
Problem with color monitor BenQ G900W лblack tsvyan almost gone? and the predominant red hue! how to fix it
BenQ 19" monitor GENERIC pnP lcd
displays upper part (a 12 cm wide band) lighter than the down part which is normal
the cursor when in the lighter part becomes ghosty and very white
Oct 27, 2010 | BenQ G900W Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
MY SCREEN ON MY LCM-17v8 MONITOR TURNS COMPLETELY WHITE AFTER FIVE MINUTES!
Generic problem for all Monitors Benq lcd Displays only white var g_tryMail = 0; MessageRate.ThreadID = 421124; MessageRate.ProductID = 689784; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse shared by 2 users posted by MatrixNet on Mar 02, 2008
Comment posted on Oct 26, 2008I ended up replacing the bulging capacitors on the board inside, and now it works. Thanks for all the comments and help.
Feb 20, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Most often the all white screen is the result of a missing voltage to the LCD panel. We usually find an open fuse on the panel circuit board. Unfortunately replacing the fuse does not usually fix the problem.
Mike
Mar 02, 2008 | Computers & Internet
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
BenQ FP791 17" LCD Monitor Logo
104 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
