Question about Garden
How do I change spark plug on Yardman riding mower.
I have the spark plug, socket and ratchet and ready to go just can't figure out how to loosen plug.
thank you,
LindaC/senior lady :-)
  • LindaCinOK Jun 03, 2009
    okay I was doing it correctly. Must be really snug in there. Will work on it more tomorrow.
    thank you so much for reply.
    LindaC
    Problem Solver:
  • 4 Answers
Turn left to loosen and turn right to tighten
Posted on Jun 03, 2009
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
How do i replace a spark plug on a honda cub
find the plug first then take a 5/8 plug socket and ratchet turn the plug left to loosen install new plug tighten turn right to tighten the plug should already be gaped make sure the numbers and letters on plug match and dont put a american plug in a japanese engine
Sep 26, 2014 | Garden
With the information provided, it sounds like the safety shut-off switch is bad. Can you do a continuity check on the switch?
Dec 11, 2013 | Garden
How do you change spark plugs in a 2002 buick rendezvous cxl
When you change spark plugs make sure your engine is cold, if the engine is hot you have a chance of breaking the ceramic the plug is covered with. Go to your auto parts store and buy some spark plugs. Ask the auto parts clerk what the plugs need to be gapped at or you can have them do it. When ready to change plugs, again make sure engine is cold. You will need a ratchet, possibly an extention and a spark plug socket. Pull the spark plug wires from their hole each individually as to keep track of which wires go to what hole. Put your ratchet, socket and spark plug socket together and insert in hole. Turn the ratchet left as the saying goes righty tighty, lefty loosy. Pull plug from hole when all the way loose, put new plug in and tighten snugly and put wire on new plug. Repeat all these steps on other plugs.
Mar 04, 2012 | 2005 Buick Rendezvous
How do I access the spark plugs on a 2007 Chevy Malibu 4-cyl?
the spark plugs are located under the coil packs, you will need to unplug 1 of the coil wire connections, and then use a 1/4 " ratchet, or 3/8" ratchet and a 10 milimeter socket to remove the nut that holds down the coil pack to the engine, once the nut is removed, then grasp the upper end of the plug wire that goe's down into the head, turn it back and forth to loosen it up, and then pull this out and you can then use a 3/8 "ratchet, and a extenstion, with a 5/8 socket to remove the spark plugs, plugs should be removed when the engine is cold, not hot, because it is easy to strip the plugs threads in the head when the engine is hot, so again, change them only when engine is cold, hope that this information has helped you.
Apr 18, 2011 | Chevrolet Malibu Cars & Trucks
Can't figure out how to change it or take it off for sharpening
you find the right size socket that fits it.(it: the bolt in the middle of the blade under the mower. Then hold the blade as you turn the socket wrench, sometimes this will be hard. this is how to do it
May 21, 2009 | Oregon Scientific Oregon Gator Mulcher...
How to change blade
Most are right-hand threads, but pretty tight.
You might need to wear gloves to hold the blade, and a long-handled ratchet & socket to loosen the bolt,(after you disconnect the spark plug ,of course)
Apr 25, 2009 | Garden
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
