Question about LG WM1815CS Front Load Washer
Water leak from the front of the machine
I have a water leak at the bottom front of the machine.
  • 1,543 Answers
Clean off the bottom of the door glass. If hair or lint builds up there, it dose not seal completely and a little water will run down the front of the machine. If that does not solve your problem, you can try moving the spring clamp (which holds the front of the tub seal)so the spring part is moved to the hinge area (a 80 degree move) instead of at the bottom of the door.
Posted on Jun 03, 2009
  • dave_denn May 19, 2011
    My LG model WM 1815CSwasher has leaked so much that the front has rusted out where the small front drain cover is located. Can you tell me how to remove the whole front cover so I sand and repaint the front of the washer? LG just gave me the company line that it was not covered in the warranty.
    Thanks for any advice you can provide
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Haier Washer/Dryer HWD1000 water leak from the bottom. When I turn the machine on, it starts taking water in, and then I see water leaking from the bottom..I checked the connection hoses, the door(front...
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
Apr 01, 2010 | Haier HWD1000
My GE dishwasher is leaking water from the bottom of the machine
first check to make sure door gasket is ok, if bad, replace and test. Make sure to remove bottom front panel during a test and inspect the motor and motor gaskets. It may be leaking here, replace leaking components as needed.
Jul 01, 2009 | GE 24 in. GLD6200L Built-in Dishwasher
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water leaking inside the washing machine
you need to replace the water valve there should be 2 screws in the back bottom corner of your control panel take them out then stand in front grab each side of control and slide foward control and then pick up and lean it back then you will see a 2 clips holding you housing of your washing machine and a plug undo the clips and unplug the wire once done that grab each side of the casing and swivel it foward then slide the bottom front foward now you can access the water valve to replace it please rate
Jan 06, 2009 | Whirlpool LSN1000LW Top Load Washer
LG WM1815CS Front Load Washer Logo
214 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
