Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Make ice somtime but leaks or act like its defrosing
I have a side by side Maytag Refrigerator, with a freezer on the Bottom. Model# I2568VES SSN 10123031JC. The problem I'm having; it make ice and it don't; however it leaks while it makes ice. Can you help me in this problem.
    Novelist:
  • 103 Answers
Hi: The ice maker is thermally protectec. In other words the freezer has to be at Zero degrees. Not just frozen, but zero. Your ice cream should be rock hard. Before you call a service tech try setting your freezer colder. Wait 24 hours before a change. It's human nature to check on the icemaker from time to time, But don't keep opening the freezer to see if it's working. You'll just dump the cold air out and make matters work. I hope this helps. Jeff
Posted on Jun 03, 2009
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from freezer side of side by side refrigerator..model MSB2354AR
Sounds like a clogged drain, If ice is on bottom of freezer floor then it is def. a clogged drain. Remove rear panel and clear drain of ice and possible obstruction.
Feb 08, 2010 | Maytag Refrigerators
Ice in the freezer side bottom of my side by side Maytag.
You are having either a defrost problem combined with the defrost drain being frozen over. Need to unplug and remove the rear panel in back of freezer to examine exactly what is happening. Some models like yours have electronic vents that cole if the control becomes defective. . The other possibilities ar the
Adaptive Defrost part number 61005988
The defrost heater with defrost thermostat part number 61006199
Visit our site or click on your model number or part number. I will be here to assist you in your repair, Thanks Sea Breeze
Click Here=> PART NUMBER AND MODEL SEARCH FEATURE
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
90 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
