SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
SOURCE: Cannot locate battery terminals on 2005 Saturn Vue re: jump
they don't want you too ... there is a terminal usually near one of the strut towers with a red cap on it and you hook up the ground to any where else metal is showing.
SOURCE: Watch going in reverse
There is no difference in watch batteries as they are produced by the certain standards. That means you have replaced the right battery.
The simplest solution would be re-replacing the battery. Just take the battery out and leave the watch without battery for 5 minutes, then put the battery back. Make sure the battery is fitted the right way (the + side usually facing up).
If this doesn;t help - let me know.
Rate, please.
SOURCE: Replaced battery for lawn tractor and nothing happens.
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
SOURCE: Turbo diesel, cranks but does not start when it is cold.
Have the cold start valve replaced, it enriches the fuel mix during cold start and check the glow plugs and see if any are bad, to test remove the wires and put test meter to ohms and one by one test each glow plug with one probe to ground and one on the tip of the glow plug see it it goes close to zero if it does not move then that glow plug is bad, replace all that you find bad.
