Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 Error Code On Whirlpool Cabrio
Same old issue, F1 error code. I emailed Whirlpool, they wanted more info from me. I responded and they never responded to the email reply. Called them on telephone and started to get run around. I purchased extended warranty and the minute I spoke about a petition and Class Action about the poor workmanship and representation, I have a service call this week. I asked the lady if this remedy will fix the issue or will I be calling her back in a few weeks with the same issue? She could not answer my question. I will post my results after the service call. Thanks Jim I have a cabrio we paid over $1200 for it. It is a piece of junk; it has been torn up over 2 times in one year, tonight f50 code! I can't wash and if anyone is up for that class action give me an email. I will sign on the line. oswald@centurytel.net
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Keep getting F1 error code on my cabrio whirpool top load washer. Can you help?
    Hello & Welcome to FixYa
    F1 error in your whirlpool cabrio indicates bad control board and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
    Kevin
    Sep 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
    Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
    Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a wtw6400sw and i'm getting the same f1 error code that alot of people are getting. even though its over 4 years old since it's a recall will whirlpool still fix it?
    F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue and yes even if its a 4 yrs old they have to fix it. Please get back to me if you have any other questions.
    Kevin
    Jul 31, 2011 | Whirlpool WTW6400SW Cabrio Washer
    The f1 code pops up
    Hello
    F1 error with your whirlpool cabrio is a common issue with these types of washers. This error indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known issue for them. Please get back to me if you have any other questions.
    Kevin
    Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code, what is the part I need to fix this
    The F1 error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I beleive Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Mar 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error on cabrio washing machine
    Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
    • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
    • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
    • I'll let you all know how it goes after the repair..
    Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Hiding within your washer should be a secret coded booklet that has all the error codes that don't appear in the user's manual.
    F1 generally means the Central Electrical Control Unit (as in cars, etc) it is the onboard computer. It usually inicates a fatality.
    If you do not have the skill & tools to test the guts of this computer, you're stuck replacing the CECU.
    BUT if you have the skill & tools then there are three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and replace.
    The Unit is normally around $200 to replace, BUT aren't you still under warranty????
    If so get Whirlpool to check it out and Replace it, lol.
    cheers,
    Bastian
    Jun 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
    Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
    Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
    What kind part i need to chang? when i get problem code f1?
    Oct 26, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    119 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
