Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero 650/F The refrigerator is not cooling fully. It will hold about 50 degrees, maybe 47 if your lucky. The freezed appears to be OK. Funny thing, the control panel for the refrigerator appears to be working backwards. When you hit cooler it displays a higher temperture and vice versa. I thought the micro controller was confused due to recent power blips so I shut the unit down completely at the circuit breaker. That did not remedy the problem. I also checked it with a digital thermometer to make sure the internal display was OK. It was within a degree or two. The other funny thing is the compressor seems to cycle off thinking its satisfied the temperature. I have not checked the fans yet. Ed at e.tremko@verizon.net or e.tremko@motorola.com
  • 1 more comment
  • ETLABS Oct 26, 2007
    Thanks for the tips, the Re value is 48 so it looks like the evap is bad.  I've called for service and they are going to come and confirm.  Sub-Zero said that if it's the evap they'll cover it -- THANKS.  I still don't know why the refrig controls work backwards  - "warmer causes temp to go down" and "colder causes the temp to go up" but I'll have that checked at the same time.  I'll let you know the final results.  Much appreciated.
  • MNelson Apr 01, 2008
    Our refigerator is about 10 years old. It is not keeping cold. It's a side by side. The freezer appears to be working properly. I have turned the knob that regulates the cooling from 5 to 7 and now to 9. Nothing seems to work. Do you have some suggestions?
  • MikeMull May 19, 2008
    Sub Zero 650 freezer srction ok but refrigerator wont get cool - sounds like Refrigerator Evaporator may be the problem to be diagnosed. Where do I contact Sub-Sero in Calgary Canada. Mike 403-271-1867
  • 175 Answers
Get into diagnostic mode by pressing and holding either colder key, then pressing on/off. You can use the colder key to scroll through 5 reading labeled fe, re, f, and r  look at the re temp. is it higher than 38? if it is you probably have a freon leak in the evaporater refridgerator (call sub zero...they will completely pay for this issue, even past the 5 year warranty)  If the temp reads really low (like 10 on re or something) you probably have a bad fan or fan switch in the fridge portion. this unit has seperate compressors and freon for the fridge and freezer..hence the lack of problems in the freezer. hope this helps!
Posted on Oct 24, 2007
Looks good what are all the definitions of fe, re, f, r, and ? (you said there are five. How do we return to normal operation? I don't want to wind up in 'showroom' or 'sabbath' modes.
Thanks
Posted on Jan 03, 2008
Why would a sub zero model 650f freezer freeze up ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
Fridge does not stay cold but the freezer works
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Sub-Zero 650 / O Bottom Freezer...
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
We have our Sub Zero model 650 frig set to 35 degrees, our usual temp, but suddenly it won't get lower than 50. Freezer seems fine.
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
Jun 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezer stuck on -20 degrees
well it depends on how long the door was open for during the cleaning, your evap coil was unable to cool the unit due to the warm air coming in, that will cause the evap coil to over frez . un-plugging the unit may work but the best thing to do is force it into a defrost you can do that by pressing and holding the ice key on the key pad for 10 sec or till you hear the freezer shut down this will thaw the ice on the coil and the unit with come back on within 20 to 30 Min's
Jan 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550
You probably have a freon leak in the evaporator coil.
Nov 01, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,274 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
