Question about Ecoquest Fresh Air Air Purifier
Install Plate Displayed
I just got through cleaning my Fresh Air Purifier. After reinstalling the screen, filter, and purifier plate I turn on the unit and when I try to turn on the purifier I get the message "Purifier Off ** Install Plate ** " The plate is in good condition and is making contact with the electrode tabs. Any ideas what is wrong? I replace the plate with a new one put when i turn the unit on it still say need to replace the Purifier plate and the purifier will not come on hit the reset button put nothting happen
  • 80 Answers
Call toll free 1-877-710-0057 and they will gladly help you.
Posted on Jun 06, 2009
2 Suggested Answers
Dutch7773
  • 31 Answers
SOURCE: Install Plate Displayed
Hi Wayne, glad to hear it's working again. Sometimes turning it off and let it sit for a while does clear some of the problems weird enough.
I'd appreciate your feedback.
Eric
Posted on Feb 08, 2009
I cleaned purifier plate and filters and purifier still won't workon my fresh air machine
The air purifier filters which need to be washed lose their efficiency very fast and need replacement every few months . I think its time you switched to a better air purifier like this with superior filters which last longer and can be cleaned using a vacuum cleaner Premium Air Purifiers with e2f technology
Oct 22, 2014 | Air Purifiers
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
I want to take my ecoquest fresh air apart to clean it, but do not know how, i have misplaced the manual
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions on the sides of the back grill that has a plastic tang that hold the back grill to the machine. Press the back grill inwards to allow the tangs to clear the sidee and the back grill should now be easily removed. Remove the two thumb screws on the top corners to remove the filter. Once the filter is removed, then you can remove the purification plate and remove the two screws that hold the RCI cell. The RCI cell and filter can be cleaned by vacumming out the dust and dirt.
The purification plate can be cleaned with a old toothbrush and a water and amonia solution. Scrub the metal grid with the toothbrush. Do both sides and then rinse with water, allow it to dry completely before reinstalling the plate. After every part is cleaned reassemble the purifier, and plug it in. Then press the reset reminder button on the front of the keypad to clear the "perform cleaning" message. This message will appear again after the purifier runs for 30 days to remind you to clean the purifier. Hope this helps you.
Oct 09, 2010 | Ecoquest Fresh Air Air Purifier
Fresh air is reading perform cleaning. exactly what does that mean,I cleaned the filter and the plate but it stii reads perform cleaning.HOW
After you have cleaned the filter and plate, reassemble the purifier. Plug it in, turn it on, when the message perform cleaning reappears, press the Reminder Reset button on the purifier to clear the message. Now you are good to go for another 30 days.
Feb 22, 2010 | Ecoquest Fresh Air Air Purifier
I do not know how to clean it. It is called Fresh
The Fresh Air has a reminder on the LCD to Perform Cleaning. This reminder will display if the purifier runs for 30 days. When this reminder is displayed perform the following steps to clean your purifier.
1. Cleaning the Case:
Wipe the unit with a soft cloth dampened with water. Do not use chemicals or solvents. Vacuum the front and rear grills to remove any lint buildup.
2. To clean the lint screen, RCI cell and purification plate:
3. To remove the back cover:
Remove the plug from the back of the unit. Unscrew the screw above the plug socket on the back cover. To remove the back cover, press the back sides of the back cover to unlatch and tilt the bottom of the back cover to remove.
4. To remove the rear lint screen:
Remove the two thumbscrews holding the top of the lint screen. Remove the lint screen by pulling back the top of the screen, then lift it up and out.
5. Removing the RCI cell:
Remove the RCI cell connector by pressing the connector locking tabs. Pull the connector straight out to unplug.
Remove the RCI cell by removing the two thumbscrews. Slide the RCI cell down and out of the unit.
6. Cleaning the RCI Cell:
Remove the RCI cell and carefully vacuum accumulated lint. Do not wash the RCI cell. Damage from water may result.
7. Rear lint screen cleaning:
You have two options
  1. When visibly dirty, simply remove the rear lint screen from the unit and with a duster attachment on a vacuum, remove the heavy particulate.
  2. In addition to step 1, the filter can be washed with hot water (do not use soap). Allow to dry prior to reinstalling. Replace if damaged.
8. Cleaning the Purifier Plate:
Remove the plate from the card cage by grasping the middle edge nearest to you, and slowly pull it straight out. Clean with mixture of one part water and one part ammonia. Place plate and ammonia mixture in a dish and allow it to soak for no more than 10 minutes. Remove plate and scrub with a toothbrush. Rinse thoroughly and air dry for 24 hours or use a blow dryer to dry thoroughly.
After all parts have been cleaned and are thoroughly dry, reinstall components in reverse order. Turn the purifier on, and on the key pad, press the reminder Reset button to clear the Perform Cleaning message.
If this has been helpful, please rate this solution. Thanks
Jan 28, 2010 | Ecoquest Fresh Air Living Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Every time I try to turn the purifier on it says install plate
The suplier switched to different electrical parts during the 3rd to 4th yr of Fresh Air manufacturing. The electrical connectors to the plate would rust and so would the screws! (Especially when you don't keep the lint screen clean! The oxidizers stay inside and try to oxidize the metal parts.) That makes for a bad connection and creates a "plate" readout. Suggest you clean the visible electrical connectors first to the plate assembly, all the way to the touching of the plate. They may just fall off. Been there! Easy to fix.
Sep 23, 2009 | Ecoquest Fresh Air Air Purifier
Eric
Dec 25, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest fresh air repair
Regardless of unit the purifier plates may need replacement. How are the plates cleaned? Could it be that there is a residue from the cleaning agent present after cleaning? With new plates there is a little oil on the plates to prevent oxidation when in storage or transit. A little rubbing alcohol would do the trick.
Make sure the plates are dry before putting them back into the unit.
If the plates are seated right and clean you should see a faint purple glow on the plates when the unit is on purify.
Let me know if that's the case.
Eric
Dec 18, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
Sep 29, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
820 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Kory Ronning
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
