Question about Kodak EasyShare V1233 Digital Camera
It was working one minute then the next it kept shutting off
After v1233 turns it on shuts its self off
    Sniper:
  • 71 Answers
John,
Generally, this is a battery issue. Check the battery and make sure that all contacts are clean (inside the camera and on the battery itself). You can do this by using a pencil eraser to clean the contacts. If this doesn't work, try charging the battery for a full 24 hours. If this doesn't work, take the battery to a location that services batteries. If the battery checks out, go into the camera and look for the reset button, which is similar to those located on phones or other electronic devices. This will set the camera back to factory specs and may clear the issue up. If this doesn't work, take the camera to a repair shop, or, if it's still under warranty, send it back to Kodak for evaluation. Generally, if the camera is under warranty, this is free.
Posted on Jun 03, 2009
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Panasonic th-42pe7u had messages " SEE YOU NEXT TIME "
Only a thought here: next time it comes on enter and check to see if sleep timer is set to turn off set or not.
Apr 29, 2012 | Panasonic (TH-50PZ700U) Television
Delonghi magnifica door won't stay shut
I had this problem. The door didn't snap when I shut it and it would pop open and stop the brewing. It was an easy 5 minute fix.
I removed the drip tray and the black plastic bin where the spent coffee grounds are expelled. With a flashlight I could clearly see 1/4" to 1/2" caked coffee grinds lining the back of the cabinet at its base. This residue kept the bin from seating correctly. Because the bin wasn't all the way back into the cabinet it put pressure on the door and kept it from latching. I cleaned out the buildup with a small spatula and a brush and the door latched perfectly again.
Apr 01, 2012 | DeLonghi Magnifica 3300 Espresso Machine
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Please help me. My Kodak Easyshare digital camera switches off!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Apr 19, 2009 | Kodak EasyShare V1233 Digital Camera
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
My kodak easy share v1233 camera turns on the turns off right away. I have the same camera model with the same problem.I went to ritz camera and was told to buy a new battery.I purchased battery and...
hi i was having the same problem with my polaroid camera my solution was that the bottom lid to the battery compartment was taped shut. and when it came loose i could only keep the camera on by holding the tape in place to keep it shut. now it works fine hope this helped some.
Jan 02, 2009 | Kodak Easyshare V1233 12.1MP Digital...
I can't get my double oven to self clean.
Try shutting off the main breaker for a minute or so and then turn it back on and set the clock. It worked for me. I've had to repeat it the next time I self clean though.
Jan 01, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My hp starts and then shuts its self down after a few seconds
Try disconnecting all the USB and peripheral devices that you have recently attached and restart the machine.
If that doesn't work it's either a virus issue or a cpu overheating issue.
Boot in safe mode and try running an antivitus first. If it detect a virus, remove it.
If that doesn't work. Try to monitor the CPU temperature in the BIOS or by downloading this program
http://www.almico.com/speedfan.php
If you see the temperature over 60-70 that's too high and that would be the reason behind your problem. In this case you will need to fix your cpu fan or buy a new one.
Oct 27, 2008 | CTX S762A 17" LCD Monitor
Kodak EasyShare V1233 Digital Camera Logo
2,138 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
