Question about Sewing Machines
Bobber knotting up
Hello, I have a New Home Sewing Machine, model JA1508, and everytime I try to use it the bobber thread gets knotted up and the machine locks up. I have adjusted the tension and still having the problem - any suggestions? Thank you
  • 25 Answers
First check that there is no thread remands in the hook race.Try tightening your bobbin case cover little by little.
Posted on Jun 15, 2009
All seems fine & threded correctly but will not stitch [knot]
from your description I guess that the knot is under the material
If so then the top thread is too loose
tighten it up a fair bit and use scrap material until you get it right
Dec 09, 2015 | White Sewing Sewing Machines
When sewing the bobber thread bunches up underneath, and breaks off. I have tried djusting the bobber tension screw, and upper needle tension to no avail. How often should I oil this machine?
1. Your bobbin should have one drop of oil on the race (little area that the bobbin rides on) around two bobbins that you have emptied.
2. The top tension is way too loose. When you put the pressure foot down pull the thread (top) to see if there is tension. Start at four is a rule of thumb.
3. I have included some rules to follow when you are setting tension.
May 08, 2015 | Sewing Machines
Bobber mechanism will not spin the bobber
since it's set up for six years, it would be a good idea to have the machine serviced. it setting up may be the cause of the bobbin spindle not working
May 08, 2012 | Brother XL-2600
I ran out of thread while sewing and now my machine won't run. Do you have any suggestions?
did u jam your thread in your bottom bobber you could have thread jamed..
Apr 09, 2011 | Brother LX3125 Sewing Machine
Bobbin thread won't come up.
I had a received a sewing machine and it was doing the same thing.
I brought it to a sewing place to get it checked out.
They said the timing is off and they fixed it bought it cost me $68.00.
Rose
Apr 28, 2009 | Singer Tiny Tailor TT700
Singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Apr 23, 2009 | Singer 7436 - INGENUITY
The thread knots up under the feed dog on about the second stitch
hi! well, you can try to set up your thread accurately followed this
53de094.jpg fig.bobbins se up of thread.the thread should be clockwise rotation coming out to bobbins casing,insert thread on slot to acquired bobbins tension.after setting up you insert your bobbins on shuttle
casing.next set up your upper thread tension.on fig is just a sample.9cbc7d3.jpg follow the red thread set, try this on single straight sewing with dial stich set up to # 8 range to #17,Dial tension to # 3. use cotton/polyester foe sample sewing. try on hand maual sewing first several time before applying foot pedal to avoid needle breakage,
Mar 17, 2009 | New Home L-373 Mechanical Sewing Machine
Consew 230 sewing machine...will not pick up bobber thread
needle should be 16x257 Industrial machine needle with no flat side.
It does have a long groove on one side and a scallop just above the eye of the needle on the other side. On this machine the needle is inserted so that the long groove goes to the left and it threads left to right.
The thread breakage may be caused by a rough place on the hook. You need to turn the machine on it's back and look and feel all the way around the hook assembly. If you find a rough spot it can be removed with an emery stick. If it's not a rough spot, then the machine is probably out of time.
sewman7
Mar 16, 2009 | Sewing Machines
Sewing Machines Logo
195 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
