Question about Hitachi 53FDX20B 53" Rear Projection Television
Color convergence "whacked out"/blue shadow to right side
Hi...Have a Hitachi 53FDX20B...manufactured July 2002. Color convergence is going--started to in October...getting worse b the month...blitzes in and out of synch , especially at start up for about 15 minutes...and the Blue color is now always "off" to the right slightly, causing a now permanent blue shadow. Tried the "magic focus" many times...shows either a "4" or "5" after finished, but seems to do very little if anything. Also has a slight "burning electronics" smell coming from the area where the 3 bubs are when first turned on for a few minutes(I took off the bottom back cover to investigate). All 3 bulbs look ok--a little dusty, but ok. Not sure if I need a new amp, new bulbs, both, or something else. Thanks!
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Color convergence
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiColor convergence "whacked out"/blue shadow to rig - 0667c5f.pngnvergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
  • 110 Answers
Install the Convergence Output Repair Kits for
53FDX20B Part# X480297
Posted on Jun 03, 2009
Hitachi 53fdx20b has yellow line on top and bottom an well as blue, all color if off. What is the problem and how much would it cost to get fixed or can I fix it myself?
It sounds like a convergence problem and is typical for many projection sets.
Parts cost would be under 25 dollars.
The repair consists of getting at and replacing two convergence chips and being able to solder is also involved as they have 18 pins each chip.
Let me know your skill level and I would be happy to help.
Oct 22, 2011 | Hitachi 53FDX20B 53" Rear Projection...
Red color on every thing in pitcure.
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 21, 2010 | Hitachi 53FDX20B 53" Rear Projection...
We have a blue tint and a shadowing effect that makes it appear to have a double on the screen of the same figure / word(s)
This problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or picture look like 3D pictures.The tv convergence board,it dead.Require,must be changes 2 STK convergence ICS and some or all it resistors to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 02, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I have the Hitachi 53FDX20B Manufactured in October 2002. It had the convergence problem where the upper left corner was a mixed up coloring and kind of a wavy line that didnt move. Color correction...
You need to replace both of your convergence ICs STK392-110s
use 120s Mats has them 1-800-628-1118 Check Low ohm resistors near ICs 1.8ohms 3.9ohms 2.7ohms etc... RK48 RK50 RK54 RK58 RK60.
On front of convergence board is a blue contact switch this is how you enter convergence pattern R/G/B to adjust convergence,
you can remove Front bottom panel and see the contact switch from front of TV With TV on Press and release then Pattern should come up. When you call Mats ask if they have Convergence Kit that has ICs and resistors in it!
Sep 26, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Green shadow
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board 2 STK convergence ICS and some or all it resistors are dead.All these parts,must be replaceed to solved convergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I have a hitachi projection tv, manufactured may 2001, and one side is shadowing. do u believe this to be a convergence problem?
it sounds like you have convergence problems
you can try going into the menu and if you can not correct it there the convergence circuit will have to be repaired
Jan 20, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi Big Screen TV 46 inch Problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 06, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 53FXD20B Spots with colour
take your tv to a tech and have them check your tv the color module could be the problem or the the convergence module.good luck.
Apr 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
581 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
