Question about Canon PIXMA MP780 All-In-One InkJet Printer
Printing - Black ink not filling in completely
Printing, just in black, is not complete.  Blank stripes running through the lettering.  Have done tests, cleaned heads, test print looks fine.  But then when I go to print the document, it has slashes of missing black.  Color seems fine.
Have been using the same type of cartridges for some time.  Changed out to a new one.  No difference.  Cleaned the holes with a bit of alcohol.  Seemed to help, then regressed.
TY!
  • 1 more comment
  • Meetoo Nov 12, 2007
    Took it in and the purge assembly was cleaned. they said the print head was fine. Worked beautifully for a week and began doing the same thing. Taking it back in again today to the repair shop.
  • Meetoo Nov 13, 2007
    Have had it about a year and half now. Love it when it works. Shop switched out the generic black cartridge, wiped out the inside again, put in a Canon cartridge and it worked just fine.
    First problem I have had with the generic cartridges. Have used them from almost the beginning. Shop Guy hates them. Spoke to another tech, he said there isn't much difference. Will change it out and see what happens. TY!
  • drossshaw Nov 25, 2007
    My printer won't print black. All the colors are fine. I have swapped out cartridges but still no black will print. Any ideas?
    Genius:
  • 1,601 Answers
Does the test page come out good or the same?
Posted on Nov 12, 2007
  • Thomas Christopher
    Thomas Christopher Nov 12, 2007
    good idea.How old is the printer? If it is under warranty, let them mess with it.
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Colour ink not printing
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the "Ink" option in the printer driver may be set to "Black" instead of "Color" or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged.
A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, turn the printer off overnight and try the cleaning cycles again.
Try a new ink cartridge. Also, make sure you are using a genuine ink cartridge and has the same number as your old catridge.
Jun 20, 2011 | Computers & Internet
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
DYMO Labelwriter 400 prints very slowly and incomplete
put in new batteries. The ink is operated by heat, hence you will need to put in new batteries and this should solve your problemn
Jun 10, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Troubleshooting in scanning and printing
You have to reset that cart. before you fill it there should be instructions on how to do this on the refill kit you bought, you cannot just fill the cart and put it in the printer you will dmage the print head if you have not already done so. I cannot see what was done so I could not give you a solution but only tell you that the ink needs to be charged before you put it into the printer!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Button sequence for head test (to look for banding)
Turn the printer off.
Load a sheet of white laser paper.
Press and hold the "Power" & "Ready/FF" buttons at the same time.
Release the "Power" button, and keep pressing the Ready/FF" button.
Right after you release the "Power" button, count 4 seconds, and release the Ready/FF" button.
Immediately, press and release the "Ready/FF" button one last time.
The printer should start printing a series of letters, numbers, horizontal lines and a black solid bar at the bottom of the sheet.
Once this test page is completed, turn the printer off to stop the test.
Feb 06, 2009 | Alps MD 1300 Thermal Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Printing in stripes
Possibly time to replace the printer.
Mar 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
151 people viewed this question
old marine
old marine
