Question about GE Profile Harmony DPGT750EC Electric Dryer
No heat and No blowing
The dryer will run through a cycle but there is no heat production and it is not blowing. Could a thermastat problem cause the blower not to work? I tested the heating element on the ohm meter and it checked out fine. Can anyone help with what needs to be replaced?
  • 864 Answers
Clogged lint filter, exhaust vent or outlet would reduce air flow but there would be some heating unless a high limit safety switch has tripped and needs to be reset.  There may be aa air flow switch that prevents the element from heating up if no air is flowing.  Blower wheel may have broken off at connection to motor shaft.
Posted on Jun 03, 2009
Dryer does not heat but spins, what should i do?
Have you cleaned the vents out lately this could be your problem. The thermal fuse may be blown if so the operating thermastat may have caused it to blow. Check all thermastats , the thermal fuse, the high temp cutoff and the heating element. Be sure and clean the vents inside and out sometime something will get in the fan housing and slow the fan down or stop it.
Dec 05, 2010 | Amana NED7200TW Electric Dryer
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Will not heat
Are you getting 220 at the heating element from one lead to the other
Mar 29, 2009 | Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
What goes on in the dryer as it is being used?
customer selects cycle
customer pushes start button
motor starts, motor switch closes and turns on element or igniter
depending if electric or gas
tub turns and heat dries clothes
thermastats cycle during run not to overheat clothes
timer cycle ends
you get clothes out now dry and put on
Apr 19, 2008 | Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Whirlpool dryer LGR5636PQ0
I replaced the heating element and had the old one checked and had the thermastat's checked as well and it still does the same thing, will not blow hot air and will not cut off when cycle is supose to be finished, what should I do?
Feb 08, 2008 | Whirlpool LER5636P Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
217 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
