Question about Weatherproof WT-12 - Single Circuit Transformer - Landscape Lighting
Landscape lighting transformer won't keep time. Anything I can do other than getting a new one. It seems like I have to get one every six months. Also my lights frequently go out, but if I give them a slight tap they come on. This would seem to be a loose connection to me, but everything seems snug. Any thoughts.
  • 104 Answers
If its only the timer part that doesnt work why dont you buy a normal plug timer [you know the ones you use for home use like radios and light etc ] and plug the transformer into that and then set the timer and plug that into the outlet , there is no reason that would not work , hope this helps smirf617
Posted on Jun 03, 2009
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
No Power to my landscape lights from transformer. Thank-you
Disconnect the wires on the transformer that go out to the lites. Voltage should be 24 + volts. If not then the internal safety fuse is burned out. You'll have to get a new transformer. If voltage is present then the wires to the lites has an open which will stop the lites from working.
Jun 18, 2015 | Hardware & Accessories
Have Malibu ML300RTW Transformer...
Doesn't seem to me it could be the transformer/controller as it either puts out voltage and current or it doesn't. I can't think of any way it would selectively operate certain bulbs. You said wiring is fine, but you should check voltage at the end of the line to ensure it's getting close to 12 volts all the way down the wiring. If not, there may be a problem between transformer and misbehaving bulbs. Doesn't seem likely that 5 bulbs would go out a once, but that would be all that's left.
May 15, 2014 | Intermatic Malibu 300W Power Pack...
Replaced the thermostat on a rbhc-24 with a honeywell and unit won't run now
transformer has a fuse buried in the windings making it impossible to change. It's new transformer time.
Feb 27, 2013 | Heating & Cooling
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
I have this blackberry phone "BOLD" almost for a year now. The problem is this some keys won't function....i keep pressing but no luck..It won't type anything on screen. I took to the...
Get a new phone. People usually get new phones after six month as today's cellphone are made with planned obsolescence (they are made to not work after so long of use)
Jun 20, 2011 | RIM BlackBerry Bold 9000 Smartphone
The weller 8200n does notheat up
Make sure the tip is tightened fully, use a 5/16 wrench to snug it down.
Feb 28, 2010 | Weller 8200 Soldering Gun
Malibu landscape transformer
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
Oct 29, 2008 | Malibu ML600TW - Low Voltage Power Pack -...
Weatherproof WT-12 - Single Circuit  Transformer - Landscape Lighting Logo
292 people viewed this question
Top Weatherproof Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Weatherproof Hardware and Accessory Expert? Answer questions, earn points and help others
