Back to:
Tags:
NEC MultiSpin ND-1100A  DVD+RW Burner
NEC DVD+RW ND-1100A (by 2 users)
posted by cschullo on Oct 24, 2007
Can this drive burn onto dual layer dvds?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by sleepless54, posted on Mar 31, 2008
I was told by the store electronic guy that I could use Memorex DVD+R DL on my burner. I have tried several times and my Burner does't even acknowledge the disk. Is there a setting on the burner to allow DL? Or maybe there is a software. I can't afford to buy a new burner.
Thank You for your time.
Waiting to hear from you.
email:-svalois_134@sympatico.ca
Best Solution
posted on Oct 24, 2007
FixYa! (100)
fire sine
Rank:Wiz Wiz
Rating: 82%, 349 votes
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Rating Locked! (?) cschullo has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on NEC DVD+RW ND-1100A:
I don't want to Accept this solution
Can you Help with these CD and DVD Burners problems?
CD and DVD Burners
hi ive down loaded a firmware from the LG site as my...
CD and DVD Burners
Windows cannot load the device driver for DVD/CD-ROM...
CD and DVD Burners
My problem is that my long-term DVD R/RW drive,used...
CD and DVD Burners
i have lg mobile c2500 i dont now which software should i...
NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
My Nec ND-1100A DVD+rw will read discs, but will not write...
Loading problems.
Repair Service
Find CD and DVD Burner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
