Question about Whirlpool ET8CHEXSQ Dryer
Whirlpool oven RBD275PDT12 error E6 F2
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 after display out for 12 hours. My daughter was cooking Friday night. She said she saw the display say "end". On saturday morning display was dead. Now Sunday display was reading E6 F2. I just heard some beeps from the oven while writing this up and now the display is dead. The beeps sequence was "medium long short short short". I'm not sure but I also may have heard another sequence of "short short long short short short"
SOURCE: oven gives code E6 F2 on panel
The problem in our oven has cleared by itself. I did see the E6 F2 error message but for now, it's working fine. Considering the customer service was only able to help to the extent of reading the error code sheet the same as I was (the sheet is behind the touch pad) and seeing how limited the solutions were, we don't think we'll be buying another Whirlpool. I was pretty insulted when the girl a customer quality called to offer me part #8300453 at half cost of $164 providing I have a service guy look at the stove and call in the part. On top of that, the warrenty is 90 days and the part is on back order. Why would the part be on back order? A) they either did not make an ample supply for inventory, B) there are many ovens needing this part. For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me someone was sleeping with a cigar in their mouth in Quality Control. Or, learning what that meant.
Enjoy the day!
Robert
Posted on Jan 26, 2008
  • 1314 Answers
SOURCE: Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
Posted on May 16, 2008
jyackle5
  • 8197 Answers
SOURCE: RBD305 Whirlpool wall Oven Beeped
You have a shorted control pad you need to replace it.
Posted on Jan 11, 2009
  • 84 Answers
SOURCE: Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Posted on Nov 09, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Tip
How to Repair Whirlpool E6 F2 Oven Code
Your Whirlpool Built-in Oven has failed and the electronic control is no-longer-available. You can have this control board rebuilt!
The common symptom is a display that intermittently goes blank, accompanied by an error code E6-F2. This is caused by a failure in the electronic control board (EOC).
The courteous technicians at www.fixyourboard.com in Austin Texas can rebuild this for you!
Control Board Part Numbers: 8302967, 4451856, 4451991, 4452890, 4452898, 4453664, 4453664.
Applicable Models: GBD277PDB6 GBD277PDB7 GBD277PDB8 GBD277PDQ6 GBD277PDQ7 GBD277PDQ8 GBD277PDS6 GBD277PDS7 GBD277PDS8 GBD277PDT6 GBD277PDT7 GBD277PDT8 GBD307PDB6 GBD307PDB7 GBD307PDB8 GBD307PDQ6 GBD307PDQ7 GBD307PDQ8 GBD307PDS6 GBD307PDS7 GBD307PDS8 GBD307PDT6 GBD307PDT7 GBD307PDT8 RBD245PDB11 RBD245PDB12 RBD245PDB13 RBD245PDQ11 RBD245PDQ12 RBD245PDQ13 RBD245PDS11 RBD245PDS12 RBD245PDS13 RBD245PDT11 RBD245PDT12 RBD245PDT13 RBD275PDB11 RBD275PDB12 RBD275PDB13 RBD275PDQ11 RBD275PDQ12 RBD275PDQ13 RBD275PDS11 RBD275PDS12 RBD275PDS13 RBD275PDT11 RBD275PDT12 RBD275PDT13 RBD276PDB11 RBD276PDB12 RBD276PDB13 RBD276PDQ11 RBD276PDQ12 RBD276PDQ13 RBD276PDS11 RBD276PDS12 RBD276PDS13 RBD276PDT11 RBD276PDT12 RBD276PDT13 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDS11 RBD305PDS12 RBD305PDS13 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDS11 RBD306PDS12 RBD306PDS13 RBD306PDT11 RBD306PDT12 RBD306PDT13
on Aug 17, 2015 | Ovens
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 after display out for 12 hours. My daughter was cooking Friday night. She said she saw the display say ''end''. On saturday morning display...
We see this error very frequently at www.fixyourboard.com. It is sometime accompanied by a display that goes blank. The boards can be fixed quickly, reliably and with a long warranty.
Jun 03, 2009 | Ovens
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool ET8CHEXSQ Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
