Question about Casio fx-300ES Calculator
I cant do graphs on the calculator but it says you can
When i press shift then setup i get a lot of choices, choice 5 says Gra, (i think that stands for graph) when i press 5 it goes back to the place where i started.
  • Casio Master
  • 7,993 Answers
Sorry to disappoint you but this is not a graphing calculator. What you thought was graph, is just the grad angle unit (degree, radian, grad).
Posted on Oct 19, 2009
My scientific calculator gives me wrong trigonometric values
That is the correct value for the cosine of 60 radians.
If you want the calculator to use some other measure for angles, press the MODE key repeatedly until you get to the "Deg Rad Gra" screen, then press the digit corresponding to your choice (degrees, radians, or grads). See "Configuring the Calculator Setup" in the second column of the first page of the manual: http://www.fixya.com/support/p1400062-casio_fx82ms_scientific_calculator/usermanual-BA0F781-pdf
Dec 16, 2013 | Casio FX82MS Scientific Calculator
My calculator is clear all setup...how to back normal function.... and how to setup this..
Press [SHIFT][9] (CLR). Then select 3:All.
Everything will be reset to default.
To setup press [SHIFT][MODE](Setup) and change the
settings you want.
1: to use MathIO display mode; 2: to use the LineIO, 3: 4: 5: to change the angle unit. 6:Fix to set Fixed number of decimals, 7:SCI scientific notation display, 8: Norm for Normal display mode. (read your manual for that).
By pressing the Arrow Down button you get other setup choices.
1: to display mixed numbers, 2: for improper fractions, 3: Stat; 4: to chose the dot or the comma as a decimal marker. 5: to adjust contrast of the screen.
Jul 18, 2011 | Casio FX82ES Scientific Calculator
How do you shade the graph
Press the y= key. Move down to the line containing the function to be graphed. Press left-arrow repeatedly to move the cursor to the far left. Press ENTER repeatedly to cycle through the different graph styles. Your choices are line, thick, above, below, path, animate, and dot.
Dec 07, 2010 | Texas Instruments TI-84 Plus Silver...
Casio fx 992s when i try to do simple calculations like 1.33360 - 1.33041.....the answer is 3.19 and other little numbers in the top right. i dont get this or like this. i want a proper 5 decimal...
It sounds like you need a manual for your calculator. You can download a scanned copy here, and it will explain what all the keys are for. For now, here is the way to set the calculator for a five decimal place display:
  1. Press the MODE key three times. A menu offering choices of FIX, SCI or NORM will appear.
  2. Press the 1 key to select FIX mode. The message "0~9?" will appear.
  3. Press the 5 key. This tells the calculator to display five digits after the decimal.
This mode setting will hold until you change it to something else, or when you turn off the calculator.
Spend some time reading the manual and work with the calculator. It's a powerful tool with a lot of capabilities. Thanks for using Fixya!
Oct 08, 2010 | Office Equipment & Supplies
How do I clear things left in the stat plot window?
To clean the slate so to speak, just reset the RAM.
  1. Press [2nd][+] to access the (MEM)ory management function
  2. Press [7:Reset]
  3. Press [1:All Ram]
  4. Press [2:Reset]
  5. Press [CLEAR] to erase the "RAM cleared" Message
Calc
Aug 02, 2010 | Texas Instruments TI-83 Plus Calculator
How do I get the graphs to be shaded?
In the Y= editor (press the Y= button to get there if you're not already there), select the graph you want to shade. Press left-arrow to get the cursor to the far left (over what looks like a backslash "\"). Press ENTER to cycle through the graph styles. Your choices are Line, Thich, Above, Below, Path, Animate, and Dot.
Apr 08, 2010 | Texas Instruments TI-83 Plus Silver...
How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Oct 10, 2009 | Casio FX-9750GPlus Calculator
I dont know how to graph
Turn calculator [ON]. If you do not see the menu icons, press [MENU]. Use the arrow keys to highlight the [GRAPH] icon.
An entry screen appears where you enter the functions you want to graph.
On the first line you have Y1= . After the equal sign enter 2[x] [X, theta,T] + 1. When finished press [F6: Draw] Your graph appears on the screen. If you see the axes, but no graph, press [Shift][V-Window] and press [F3:Std] then [SHIFT][QUIT] will take you back to the screen where you enter the functions to draw. There press [F6:Draw].
Hope it helps.
Sep 21, 2009 | Casio CFX 9850GA Plus Calculator
I cant get to the standard window on my graphing calculator
I am not sure I understand but if you are talking about the ZoomStandard graph window, you access the configuration as follows. Press MENU, Scroll to highlight the [RUN] icon and press [EXE].
Press [SHIFT] [F3:V-Window]. At the bottom of the screen you have the different options . Press [F3:STD].
Hope it helps.
Jul 09, 2009 | Casio FX-9750GPlus Calculator
Graphs
From the Y= editor:
1. Move the cursor to highlight the applicable function.
2. Select the Style menu and press 2nd F6.
3. Select the applicable style.
In this case you want Dot. The other choices are Line, Square, Thick, Animate, Path, Above, and Below.
For full details look in the section "Basic Function Graphing" in the TI-89 Guidebook.
Apr 01, 2008 | Texas Instruments TI-89 Calculator
Casio fx-300ES Calculator Logo
217 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
