Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens will not retract after being
Lens want retract after being turned off sony w35. lense remains open when. camera is turned off. when rebooted it comes up with access turn camera off and on however it makes no difference. I hv similar problem. Its a sony dsc-p7, 5.5 yrs old. Was working 3o mts again with good pics. The zoom lens wouldn't go back to IN position after camera is switched off. Setup, picture download works. Battery is fully charged. Zoom no response even while being charged and operated. kpksub@yahoo.com
  • 643 Answers
The problem is that the lens is out of alignment. if its not making grinding sounds try manually help the lens to reseat itself. if that doesnt work its not ecomical to repair unit cuz parts and labor are about 120-130 dollars.
Posted on Jun 04, 2009
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
Dec 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lens won't retract
According to Sony, storing the camera lens-down in a warm area for an extended period (a week) can help re-lubricate the retractor drive in cases like this.
This camera seems to have a predisposition to lens retraction problems. Try some gentle nudging, Even a small piece of debris can jam the mechanism, so it might just need a little push or pull.
Apr 16, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
SONY DSC W35 "Access" "Turn the power off and on again"
Yes this can be cleaned with a can of compressed air. but I feel you went above the call of duty here to repair it yourself and I congradulate you for your go getter do it yourself attidude and action. Now you might have to chalk this thing up and get a new camera as once these are cracked open its done unless you now what exactly you are doing, its like a kid in a cookie jar effect..
Sep 23, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
My lense is stuck open despite turning my camera off. On turning my camera on I am told ''turn camera on off then on'' but the lense does not retract. I am able to view all photos on the memory card as...
This is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal approach
Jul 21, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My sony camera displays Turn camera off and on again
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 09, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
manualy try to force it down. if you hear a cruch or grinding noise that means the gears are stripped and needs to be sent in flat rate usually half what you paid originally.
Jun 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
263 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
