Question about Toro Electric Trimmer
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I have a Toro 12" electric weed eater and the line needs changed. Both of my brothers, my brother in law and my son have tried to get the bottom off (where the line goes) but it will not move. They tried everything. What is the secret to this. It does not have a model number on it. Thanks. Ginger I have a 12 inch Toro electric trimmer and I can't get the spool off to change it. Any solution? toro electric trimmer cannot figure out how to remove the bottom part to replace the string
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
  • 41 Answers
Is there a bolt or theres two taps that you have to push in and pull down to remove.
Posted on Jun 03, 2009
2 Suggested Answers
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
Posted on Mar 30, 2011
Line installation
Hi bluemontel52...
Hi
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
I have a Toro Electric weed eater and cannot get spool off to change.
Did you try using a flat screwdriver between the head and the bump knob?
Aug 14, 2010 | Toro Electric Trimmer
May 26, 2009 | Toro Electric Trimmer
I have a Toro 12" electric weed eater and the line needs changed. Both of my brothers, my brother in law and my son have tried to get the bottom off (where the line goes) but it will not move. They tried...
If the knob on the spool has two small rectangular slots on opposite sides, try inserting screwdrivers in each one at the same time and then turn the spool slightly. This might allow it to pop off.
Apr 25, 2009 | Toro Electric Trimmer
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Toro Electric Trimmer Logo
3,810 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
