Question about Cameras
Memory card error samsung s1065
I have a samsung s1065 camera and recently i had quite a few photos on it and the batterys died, so i put some more in and turned it on and it took ages to come up with anything just the green light flashing really quickly, then it just said 'card error' which disappears and then the option to 'format' comes up, if u press no it turns the camera off, if u press yes it says processing for ages, then comes up with 'card error' again. I thought it was the card, but when i put a new card in the same thing happens again. The camera still turns on and everything if there is no memory card in it but i'm not really sure how to make it work or what is wrong with it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 575 Answers
When you view pics it is best to download them to a temp file if you don't want them easy to delete. once the cam views them .
Posted on Apr 06, 2017
vcrdr1
  • 53 Answers
SOURCE: Internal memory card problem
when you view pics it is best to download them to a temp file if you don't want them easy to delete. once the cam views them they clear the memory. clear simple process without paying gateway about 80 buck's
Posted on Jun 08, 2006
  • 10 Answers
SOURCE: Memory card fault or camera fault?
When the camera writes the image files to the memory card, it also creates index/information files. Without those files the camera will not display the images.
Check the software you used to upload the images with. There's probably a checkbox or option that tells it to delete the images from the card after uploading them.
Posted on Jan 05, 2009
BillB-SA
  • 2761 Answers
SOURCE: Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: samsung s1065 beeps 3 times nothing else. only
http://www.youtube.com/watch?v=TmOPab5E4bw WATCH MY VIDEO
Posted on Feb 12, 2010
  • 11967 Answers
SOURCE: my samsung s1065 camera has frozen, new batteries
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 08, 2010
Memory Error
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 30, 2012 | Pentax X70 Digital Camera
I dont have a disk and i want to download photos from my samsung camera model number S1065
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 31, 2011 | Samsung Digimax D53 Digital Camera
My samsung s1065 camera is saying "card locked "i have not put a code or anything in it so i dont know why its locked an i cannot take any photos or anything
Remove the SD memory card from the camera. Look for the lock switch on the memory card and slide it away from the "lock" position. Re-insert the SD card and all should be well.
SD stands for Secure Digital and was one of the first memory cards to have a physical security lock to protect your data.
Oct 05, 2009 | Fuji FinePix A500 Digital Camera
My camera is a samsung s1065 and it will not read my memory card. There is no photos on the camera's memory or the SD card's memory because i uploaded them to my computer using a "all in one" USB stick...
If the images were "copied" the original images will still be on the disc. Try formatting the memory stick and see if this clears up your situation. If not, write back with specifics.
Jul 08, 2009 | Fuji FinePix A500 Digital Camera
I have a samsung s1065 and I wonder if you could let me know..
One thing to consider when dragging photos to a memory card for viewing on digital camera, is which folder you are putting them in.
On my sony cyber shot, when I hook it up to remove pictures, I open the memory drive in MY COMPUTER, and are faced with two folders.
I ended up having to click into each one to find where the actual photos were, and there were multiple folders within the original folders.
I guess it is just the way the camera organizes the memory card.
Anyway, if your experience is similar to mine, and you haven't already done so, I would click down to the exact same folder in the memory card where you find pictures you take with the camera.
Drag your computer photos there, and see if they appear.
Hope that helps.
Dec 30, 2008 | Samsung Digimax S630 Digital Camera
Memory
I had thesame problem when I bought my s1065, until I opened the battery compartment & found I had no memory card in, I went to Argus & bought one for £19 50p & now I can take as many photos as I like.
Alf.
Dec 20, 2008 | Samsung Digimax S630 Digital Camera
Nov 29, 2008 | Gateway DC-M40 Digital Camera
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
116 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
