Question about Maytag SAV515DE Top Load Washer
During spin cycle the washer shakes violantly, even when empty.
And the machine is perfectly level on concrete floor. It started about 3 weeks ago, after having the machine foe 5 years.
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
THENTHEREWER
  • 131 Answers
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Posted on Nov 16, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
  • 35 Answers
SOURCE: front loader shakes bad, is level, and on a concrete floor
You will have harmonic inbalance about 800 rpm on most front load machines, causing them to shake termporarily as it ramps up on the spin cycle. Be sure to check if the shipping bolts have been removed. This is the most common mistake most people make while installing front load machines. If you don't remove the shipping bolts, it will cause most machines to shake violently and can cause damage.
Posted on Jun 05, 2009
co7196
  • 3433 Answers
SOURCE: making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Posted on Jun 15, 2009
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
My maytag washer shake a end of rinse cycle.
After the rinse cycle, the washer rapidly spins the tub to get as much water out of the clothes as it can. It works basically the same way as a salad spinner. If the weight of the clothes in the washer is not balanced, the washer will shake and maybe even jump around during the spin cycle. This is pretty normal. If all of your jeans end up on one side, and your t-shirts on the other, the jeans will hold more water, their side of the tub will be heavier, and the washer will shake a lot during the spin cycle.
If the washer is shaking too much, open it after the rinse cycle (wait for the tub to stop before reaching in) and spread the clothes out evenly in the tub. Try to balance the weight. Then close the lid/door and let it continue spinning.
Mar 05, 2011 | Maytag Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Open Questions:
Maytag SAV515DE Top Load Washer Logo
146 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
