Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Problem with embedded dirt finder
I just got this vacuum today and found that no matter how many times I went over the same spot, the embedded dirt sensor stayed red.  Can you tell me if there could be something else wrong besides a dirty carpet???
  • 1 more comment
  • Anonymous Dec 02, 2007
    Yep, brand new and I have the same problem. Any helpers out there?
  • Yuttahay Jan 02, 2008
    Ditto yep; just got it for Christmas. It worked OK for a couple of days, but now will not go green under any circumstances.
  • Anonymous Jan 08, 2008
    Have had the vacuum less than a year and is starting to do the same thing. No matter how much I vacuum the light stays red.
  • 1,673 Answers
Take the hose off at the back of the vac, should just turn then pull oull, look down inside the tube that the hose was connected to, there is a sensor there and if it is coated over with dirt, then it can't work, Clean it off and the try it, if it still stays on, then you have a bad sensor, and if this is less then a year old, you have a one year warranty on this. Take it to a warranty shop and take proof of purchase with you.
Posted on Jan 15, 2008
My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck the way just in case you dont have it here is the manual for your model
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt finder sensor stopped working
I had the same problem with a hoover windtunnel 6200 - u5477-900. I removed the flexible hose from top of the plastic tube running vertically along the right side of the back of the vacuum. When I used a flashlight to look into the plastic tube, I could see a clog at the bottom, where the flexible hose curved frontwards towards the brushes. I then removed the 2 screws holding the vertical plastic tube to the vacuum. When I disconnected the plastic tube from the flexible hose at the bottom, I found a clog of dirt and dog hair. After removing the clog and reassembling, the clean / dirty light now moves back and forth from red to green.
Jan 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Embedded dirt finder light stuck
The Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Dec 31, 2007 | Vacuums
Try cleaning out all the pathways you can get to. Trapped particles can mess up this indicator. Particularly check the extra mesh filter that is under the bag (there's a plastic grid that snaps over it to hold it into place). Clean that out and make sure the bag is securely in place.
Dec 04, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Oct 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Sep 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Savvy
Does this happen at both Dirt Finder Sensitivity settings?
Sep 16, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Embedded Dirt Finder green light won't come back on - stays red
The dirt sensor is a motion detector. After it gets dirty it will either stay red or stay green. You can have the vacuum serviced at your local vac shop and possibly get this fixed. Sometimes they are as good as new and sometimes they are not repairable. It will not effect anything else though.
Jun 09, 2017 | Hoover U6634-900 WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
273 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
