Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Blank screen, flashing led power light
For about a month, when the monitor was brought out of standby it would flash and be all fuzzy for about a minute and then work properly. Now it will not come on and the blue LED around the power button flashes and then flashes faster when the computer is running.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try a different monitor and make sure your still getting video from the computer.
    Problem Solver:
  • 6 Answers
This sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Posted on Mar 22, 2010
Transistors problem check your transistor and capicitor in power supply
Posted on Jun 05, 2009
  • 63 Answers
Ditto for bens comment. Also exercise the warranty if applicable. IT sounds like it's only a matter of time before a failure. Make arrangements to have a backup monitor.
Posted on Jun 03, 2009
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Blank screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 03, 2012 | Toshiba Satellite L505D-LS5010 Notebook
Red LED lights
power supply shot ... sometimes x board or y board
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Hp L1502 LCD blank, LED still flashes
just check ur lcd display cable and try to clean and c it it will cme
May 29, 2009 | Samsung SyncMaster 910T 19" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
"BLANK SCREEN, CLICKING SOUND, & NO LED INDICATED".
some electronic components on the circuit was shorted.
clicking indicates this type of problems.
Dec 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
Monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
Aug 18, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
1,379 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
