Question about Dishwashers
Water keeps coming back into dishwasher after cycle is done
The dishwasher drains but after it is done, somehow water starts seeping back up into the bottom of the dishwasher. i run the drain cycle again to clear it but after 30 minutes or so there's about an inch of water again. i turned off the water to the dishwasher but it still happens. ???? Adjusting the hose did not work. The model is Kenmore Ultra Wash Quiet Guard #16529000. The only way I can stop it or slow it down is if I turn the dial to the drain cycle and leave it there. The original problem is that the water seeps back into the dishwasher once the cycle is complete.
  • 530 Answers
Sounds like maybe one of your check valve is not working right.
Posted on Jun 03, 2009
I have a F& P Nautilus dishwasher FP 920 CEM414387 keeps coming up with u-1 and the dishwasher stops. What can it be?
Hi, U-i is a user fault which means somehow the either the water was turned off, the drawer while filling was draining at the same time, water did not enter the drawer within 3 minutes of start, or you had excessive foaming.
Is the water to the drawer on? Was there suds in the drawer?
Hit the power button far left on the control, open and close drawer. Run a rinse only cycle and see if it fills like normal, if not get back to me and I can walk you thought a test through the control to check it.
Good Luck
Aug 29, 2011 | Dishwashers
Water is not draining after wash. What might be the cause?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Apr 01, 2010 | Jenn-Air 24 in. DW861 Built-in Dishwasher
Dishwasher stops after it starts
Your dishwasher is probably draining during the wash cycle. This is usually the result of a worn out diverter valve.
Nov 20, 2009 | Washing Machines
The dishwasher wont stop drying to drain . The darin is not blocked
check the following:---- Check for hose kinks or food plugging drain hose. Start at the drain port exit
  1. Check the check valve and drain hose for debris.
  2. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  3. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  4. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  5. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  6. Check pump impeller for damage.
  7. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    thanks.
Oct 10, 2009 | Dishwashers
Hi, If the drain hose is attached under the sink, make sure that the drain hose is looped higher then the outlet it is attached to.
Most model will hold a small amount of water after draining to keep the seals moist.
I hope this helps.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Dishwashers
Water does not drain
Hi
You can :
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
    ok.
Jan 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Smell??
Check to make sure that the drain hose loops as high as possible before coming back down to the disposer or branch tailpiece drain. If the drain hose just goes straight up to the drain connection, dirty water can seep back into the dishwasher.
Oct 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
495 people viewed this question
Top Dishwashers Experts
Owen Barnes
