Question about HP PSC 1315 All-In-One InkJet Printer
Paper jam NOT
I'm getting a paper jam message when there's no paper jam.
The paper will load about half way, and then a light will come on saying there is a paper jam. Nothings jammed, so I don't know what the deal is. I've taken apart the back to see if there is something jammed in there, but theres nothing wrong. I've turned the printer and computer off and on many many times, but it's not helping.
  • 3 more comments
  • angiec Nov 04, 2007
    I'm having the same problem...paper loads half way, then the check paper / check printer cartridge lights come on. I'm at my wits end.
  • lobeski Nov 15, 2007
    I took my printer apart and found that a little black plastic piece had broken near where the print cartridges are installed. It appears that that piece is at times under pressure, so trying to glue it seemed futile. I could hear the piece rattling around in the case when I moved the printer, and had tried all of the other ideas for fixing the problem.
  • sk low Nov 17, 2007
    my printer hp 1315 always show there is paper jam but there was none.
    Roller is rattling when printing. Instead of printing one paper at at time it suck in a few papers cause it to jam.I can scan & print but it cannot print from PC
  • Anonymous Dec 02, 2007
    I'm also is having the same problem...paper loads half way, then the check paper / check printer cartridge lights come on. I cleaned the track, lots of black stuff came out. still not working
  • lobeski Feb 09, 2008
    This was a great printer while it lasted, but it's obvious that it had some serious engineering problems. I took my printer, with the broken plastic piece that couldn't be repaired, to school where we use it as a scanner. This experience makes me appreciate the equipment that works well and lasts.
    Novelist:
  • 123 Answers
Hi
Try this, remove all paper and bins.
then get alcohol and a clean cloth, clean all rollers and tires.
You will get a lot of black dirt and stuff off after cleaning
really well try, if it works for a while then yhat was your problem,
if it is only temporary then tires will need replacing.
Comment by check it right,
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 08, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Feb 08, 2008
     Otherwise
    1- try to make an internal test ( hit one of the buttons on the printer
    to make a test sheet. this is actually a self diagnosis)
    2- make sure the paper size is the correct,
    3- check sensor next to where the paper goes in ( try this test :
    when paper jams halfway, leave it, turn off printer and on. does it show
    a paper jam? if no the sensor is bad. if yes are you using paper with holes
    for binders? turn paper other way and try.
    Good luck.
     Otherwise
    Good luck.
Throw the damn thing away and buy a brother printer, they never jame
it is not worth my time and frustration to try and fix a problem that is clearly just a faulty product
Posted on Jan 01, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
then get alcohol and a clean cloth, clean all rollers and tires. You will get a lot of black dirt and stuff off after cleaning really well try, if it works for a while then yhat was your problem,if it is only temporary then tires will need replacing.
Posted on Nov 08, 2007
  • CheckitRight
    CheckitRight Nov 16, 2007
    1- try to make an internal test ( hit one of the buttons on the printer to make a test sheet. this is actually a self diagnosis)
    when paper jams halfway, leave it, turn off printer and on. does it show a paper jam? if no the sensor is bad. if yes are you using paper with holes for binders? turn paper other way and try.
    Good luck.
Why does my paper jam half way as it tends to
I had this problem till I started using heavier weight paper. My wife was buying the cheap really thin paper and it was no end of trouble.
May 27, 2010 | Lexmark X4550 InkJet Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
May 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
HP PSC 1315 All-In-One InkJet Printer Logo
222 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
