Question about Cameras
Dropped camera in the sand, and now it comes on and goes off
I dropped my camera in the sand and now it just comes on and goes off
  • 643 Answers
Use a vacume to get any grit out. DO NOT BLOW THE CAM WITH AIR!! you will send more sand inside the unit. usually its inside the lens housing.
Posted on Jun 03, 2009
When pressing the power button, the shutter opens, the lens comes out, the screen comes on for about 2 seconds. Then the screen turns off, the lens goes back in, but the shutter stays open. I let someone...
Look closely for sand particles that may be lodged around the gaps of the lens barrel. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Kodak Easyshare C182 12MP Digital Camera
When i turn on my camera it turns on then goes to a black screen and says lens error 0x0311. It was never dropped or anything its only a few months old it just started doing this one day.
There's a really good blog about fixing lens errors, and you can find it here. You don't have to have dropped it to cause this problem, it can be sand or grit in the mechanism, or it was accidentally turned on at a time when the lens could not come out.
Jan 20, 2011 | Cameras
How do I get sand out of my OlympusFE-100? Dropped it in the sand now it won't turn on. When it tries to turn on the zoom just goes out and in several times and then it shuts down. I am hoping that I can...
I would be hesitant about cleaning it out yourself. If you use canned air, then you may make the problem worse by blowing sand deeper into the works. If you disassemble, critical alignment of the lense may be lost.
Take the camera to a Wolf's or similar, and see what they can do for you.
Jun 30, 2010 | Olympus Camedia Brio D-100 Digital Camera
Focusing Problem
hi, if you can open your camera and remove the lens unit assy(just be carefull to the flat cable its easy to be broken) you can clean by yourself just to remove the sand goes inside of the lens unit and also to the gear.make it sure you need to use magnifying glass to see the small pc of sand .some time the sand goes to the gear that cause of malfunction or not rotate properly and also the focus gear have also sand that why the focus is bad.if you can't do this just bring to service center and request for cleaning.
thank you
Jun 19, 2010 | Casio Exilim Card EX-S100 Digital Camera
My fe-340 was dropped in the sand, is there anyway
Google the words...disassemble a digital camera.
Jan 19, 2010 | Olympus FE-340 Digital Camera
I filled my Panasonic LZ3's lenses with sand and...
This camera will most likely need a firmware upgrade. You can send it in and have the company repair it for $50. That is what I recommend doing. Otherwise you may have to dismantle entire camera and spray with a can of air duster. You may get lucky enough to just clean it, but there is slight chance it messed up the firmware and it will need to be upgraded or reprogrammed
Aug 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Lens won't come out or it comes part way out and goes right back.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 05, 2009 | Canon PowerShot A640 Digital Camera
Lens won't open, & it says lens error, restart camera.
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
I dropped the camera in the sand. I turn it on and it says Lens error OX 04110000
You might try a can of compressed air, but I would see if the camera is still in warranty. I had good luck with my Canon, they sent me a new camera!
Apr 29, 2009 | Sanyo Vpc-s1070w Digital Camera
Cameras Logo
106 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
