Question about Maytag Legacy Series Top Load Washer
Making an awful ratcheting noise during aggitation and spin cycles
I have a legacy series washer model # mav208dawn that's making an awful ratcheting noise during aggitation and spin cycles The washer shakes violantly during the spin cycle. Can anyone help?
    President:
  • 3,433 Answers
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Posted on Jun 15, 2009
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
I have a kenmore 70 make ratchet noise ,will not
Probably bad lid switch. Your ratchet noise is normal during the wash cycle.
Mar 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
740 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
