Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
I have a Kenmore 3.5 Super Capacity Front Loader. I try to start it but it didn't fill with any type of water. I unplugged it and now it fills for 3 seconds then stops. The lights turn on and it will drain but that's it. I love my washer and don't want to replace it. Please help! I heard a big pop when I last started a load. Now my washer won't fill w/water. It trys and may start to fill for a 2 seconds and then that is it, it will repeat it self. Do you all think this may be the Control board?
4 Suggested Answers
  • 403 Answers
SOURCE: kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Posted on Oct 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore super capacity front loader.
Hi
The door spring came off and the boot seal was snapped away from its place, this is the only reason causing the washer to leak badly. Also, inspect that the boot seal is not cut or worn out, replace if necessary. Install the door spring as shown in the video---
Hope this helps... Please post back if you need more information.
Daniel
Posted on Apr 30, 2011
Testimonial: "Hi. My machine does not leak anymore, because, I had tech replace and install the spring that came out. Thank you for all of your help."
My kenmore he2 front loader is not going threw the wash cycle, but all the lights come on and the door is locked what could be wrong?
Hum may have a bad water pressure switch? It detirmines when the wash cycle should start according to the water level. if bad it will not signal the appliance to start washing. Also may want to check ur door lock switch if its bad it wont go into wash either.
Sep 19, 2014 | Kenmore HE2 Plus 3.6 cu. ft. Super...
Kenmore washer 3.5 super capacity. Machine spins
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Kenmore 3.5 frnt loader always has inches of H20 in rubber gasket
does your model start with 417? if so then there is a new door gasket that will help with water left in the boot.
if you have 110, then there is no new gasket/ boot...
you need to clean the drain pump sump screen.
either unit will have a clean out screen that is a removable cover on the front of the pump and it allows you to unscrew the sump filter and clean it out.
Feb 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Super Capacity front loading washer that has stopped.
Hello SMCCRAVE,
You are referring to a top loader problem.
A front loader is different the following is from the youtube page that has video explaining the possible issues!
Washing machine not spinning? This video provides information on how to troubleshoot a front-load washer that won't spin and the most likely defective parts associated with this problem. These are sorted from most likely to least likely to be the issue.
Commonly replaced washer parts:
Drive belt
Door lock switch
Motor control board
Stator/rotor
Drive motor
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore 46462 Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
56 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
