Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Audio output rca jacks don't work
Audio output jacks don't work, yes I'm plugging them into the right ones. I have a DLP rear projection 61". Is it easier to fix problem with tv rca jacks or install a separate aftermarket headphone jack. thanks David
5 Suggested Answers
SOURCE: samsung HL-S6186W DLP HDTV no audio
After browsing the forum I decided to try a factory reset...
unplug unit,
wait 2 minutes,
then on remote, press; mute-1-8-2-power (to access service menus)
it seems like it worked !
Also I found a good place to D/L service manuals...www.manualuniverse.com
Posted on Jun 14, 2008
SOURCE: TV has low sound output through right speaker of stereo receiver
try the balence. if no joy. try the cable if you have a meter also see if the cable and see if the cable has been reversed???????
Posted on Apr 23, 2009
  • 16 Answers
SOURCE: The audio has died on my SAMSUNG HLS4266WX. The
have you used the picture-in-picture function and swapped the sound by anychance? from main to sub?
Posted on Jun 13, 2009
  • 1779 Answers
SOURCE: I have a Samsung HLR5067WAXXAA TV and a pair of
Try the Audio Output RCA jacks L-R= red/wht
Posted on Nov 25, 2010
How can i connect a cromecast to a dlp hdtv
I also bought a Google Cromecast, not knowing that my Samsung DLP TV did not have an HDMI port. I bought this product and it converts HDMI to RCA.
Website-http://www.amazon.com/Etekcity%C2%AE-Composite-Video-Audio-Converter/dp/B008FO7PQA/ref=sr_1_1?ie=UTF8&qid=1388242242&sr=8-1&keywords=HDMI+to+RCA
Dec 23, 2013 | Samsung HLN617W 61" Rear Projection HDTV
Its plugged into the cable but it s saying it isnt finding any channels on auto scan. help
It is common on the RCA---it just means not seeing any signal---does the set work via the rear audio and video jacks with a DVD etc?
Dec 04, 2012 | RCA D61W20 61" Rear Projection Television
How should I hook up a dvd player? Which one of the input jacks. I am using rca connectors
mikehomco,
On the rear of the DVD locate the composite video output and audio outputs. The connectors will be RCA females. Video is yellow, right audio is red and left audio is right. Connect one end of your patch cable to the appropriate output color. On the TV find the video input one. Connect the yellow, red and white ends of the cord to the same colors on the TV, video input 1. If your TV has a source selection button use it to locate video input one. If not use the menu. Go to input select and choose video input one. Enjoy the movie.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 24, 2011 | JVC HD-52G886 52" Rear Projection HDTV
I nedd to play my computer on this tv i need help
This being a CRT style projection set is not really designed to work with a computer/laptop.
If your computer has a composite video output, it should be able to work. This is a analog video output and would be a RCA connector. Most computers have a audio output and most of the time it is a stereo mini jack. So if you have a RCA video jack output on your computer you can hook it to the yellow video in of video1. If you have a stereo mini jack cable that has 2 RCA connectors at the other end, you would plug the mini jack in the audio out of the computer and plug the RCA Jacks into the red and white connectors of video1. Some computers will have a key you will need to press to activate the video output instead of the monitor output.
I hope this is clear enough.
Skyassoc
Nov 25, 2010 | RCA HD52W59 HDTV Projection Television
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
Nov 11, 2009 | Car Audio & Video
Conecting to souround sound
find the audio output jacks. Should be one red and one white, that say output by it. You can get the RCA Audio Jacks that plug in to the tv audio output jacks to your receiver or stereo INPUT jacks.
Aug 05, 2009 | Televison & Video
NO SOUND
Use Extneral Audio Jacks to a stereo for sound or replace audio output ic.
Feb 11, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
How you hokup sound system to the TV TP6190
on the back of the t/v connect RCA cables to the audio out (right-left) then plug the other end of the RCA cables to the input of your reciever or amp ( t/v input-aux input-vcr input any of the inputs will work but DON"T use the phono input!!
Dec 19, 2008 | Toshiba TP61G90 61" Rear Projection...
Receiver compatible with tv
yes digital suround sound is optical spdif k like coxial digital if it dont have analog outs or does it have headphone jack in front run a eth in mini jack to rca offf that to video 1 of sterio ok
Feb 10, 2008 | Televison & Video
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
