Error Code 50300, 50301, 50302 It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following: Change your wireless router's channel to 1 or 11 Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab. Where is your wireless router located? Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference. Look for other devices Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
See if there is any audio output connections on the front or rear, they will be round connectors one red one white otherwise known as Phone or RCA. You may then require a small adaptor to change the two connectors to on 3.5mm jack plug, you can buy these from any electronics shops.
Hi,All the RCA sockets are inputs so you won't be able to plug in your heaphone transmitter into those. From what I can gather you will need to plug the headphone transmitter into the 3.5mm Jack socket located on the right hand side of the TV near the RCA sockets.
If you only have RCA plugs on your heaphone transmitter you will need one of these pictured below.
You can get them from Maplins electronics or Radioshack if in the us or any good audio outlet.
The error implies that your Wii console's Internet connection may be affected by wireless interference. Try the following steps to rectify the issue:
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution. Thank you.
