The power light comes on and there is a brief flash of the message searching then all black. I've tried cycling source etc. no change
Hi! do you have experience in electronic repairing? I think your TV is
need to Diagnose siriusly.. only pro tech. can only resolved yoyr
problem! if you have experience in repairing!" can you tell me the
exact problem of your Unit!?
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no HV, you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have HV as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
All the best
