Question about JVC RC-QN2 Cassette/CD Boombox
Jvc rc qn2 manuals
Can a CD be set to replay?
3 Suggested Answers
SOURCE:
SOURCE: I have a JVC RC-ST1, I'm trying to record from CD
check to make sure the tab on the cassette is not on, as if it is, it will prevent the record button from being pushed down , thus avoiding overwriting the cassette.
If thats not the case then the record mechanism is damaged inside the cassette caddy.
Posted on May 24, 2010
SOURCE: JVC RC-QN2 - How to use the microphone on this unit?
I have a JVC RC-QN2 Boombox. There is no MIC port at the back of mine, only a HEADPHONE jack and the A/C plug port.
Posted on Jul 09, 2010
RC-800M Remote Control
Are you trying to use the Insignia RC-800M to control a TV or some other JVC device? How old is the JVC product? Most universal remotes won't control a device that was built within 6 months of when the remote was programmed. (Newer devices will not work at all with an older remote.)
The RC-800M code for a JVC TV is 11601. For a JVC set-top box try the codes: 00775 or 01775. For a JVC DVD or Blu-ray player, try 32365. The manuals for most of the Insignia devices which came with the RC-800M remote are available from the Insignia support site: http://www.insigniaproducts.com/support.html .
I hope this helps.
Oct 01, 2013 | Insignia RC-800M Remote Control
Jvc rc bx53 user manual
Heeft iemand nog een handleiding model RC-BX 530 SL ?
Nov 28, 2011 | JVC RC-BX530 Cassette/CD Boombox
I've realized that the jvc rc-bx30 can't read mp3 files. I would like to burn music to a cd/dvd and then play it on my jvc. What format should i use? By the way is there a possibility to change the reader...
Indeed the JVC RC-BX30 is a model of 1999, too old to be able to read mp3 cd. As you said you can write the mp3s to audio cd and then play them from this Boombox. You have to use the typical "audio disk" format (16bit, stereo, 44.100Hz). This format is available at any recorder software (Nero for 50Euros, or Ashampoo for free or anything else you have in your mind). There is no possibility to change the cd reader in order to be able the JVC to read the mp3 cd.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 13, 2011 | JVC RC-BX30 Cassette/CD Boombox
Manual JVC RC-EX30
You can download the manual for your item from this link: http://resources.jvc.com/Resources/00/00/95/lvt1213-001b.pdf
You will need Adobe Reader to view the manual. If you don't have it already installed, you can download it from here http://get.adobe.com/reader/
Jan 31, 2011 | JVC RC-EX30 Radio/Cassette/CD Boombox
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
Cannot find an english version for JVC RC-EX30 manual
From this link you can download the user manual for JVC RC-EX30B. Don't forget to vote for this device in order to start the download.
In case of a problem or clarification, don't hesitate to post me a reply.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 12, 2010 | JVC RC-EX30 Radio/Cassette/CD Boombox
How Do I Preset Radio Stations ?
Looked online for a manual for unit and found them with a wide price range.Check on the web or contact JVC.Make sure you have the correct model number.
Sep 23, 2009 | JVC RC-EX25 Radio/Cassette/CD Boombox
That model seems to pre-date JVC's online manuals.
Let's try a little logic here though:
- Can it record on FM?    No - Can it record on CD?   No - Can it record on tape?   Probably. And if it is set up as most such devices, it will have to be switched to 'Tape,' then 'Record' and if you don't wish to actually put anything on tape, you may still have to have one in the drive and just leave it on 'Pause.'
Sep 14, 2008 | JVC RC-QN2 Cassette/CD Boombox
How do I set the clock and preset stations.
I also had some problems to figure out how to set the time, but here is the sollution i came up with:
1. Press "Clock/Timer" until a clock and "on" starts to flash in the display.
2. Turn the "volume/caleido jog" to choose which function you want to set (alarm on/alarm off/time).
3. Press "clock/timer" again.
4. Change time with the volume wheel.
5. Press "clock/timer" when you are finished.
Apr 10, 2007 | JVC RC-QN2 Cassette/CD Boombox
JVC RC-QN2 Cassette/CD Boombox Logo
93 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
