Question about Soyo DYLT032D 32 in. LCD Television
TV volume increases/decreases and sometimes switch to TV menu screen by itself
My Philips TV volume just suddenly while watching TV increases by itself up to 100 (the highest) and when you try to use the remote control to reduce the volume, it doesn't respond at all. So I switch it off from the mains and switch it on again. Sometimes, it comes on and is normal, sometimes, it still stays up. In fact, you can see the blue light flashing as though someone is using the control to increase the volume. If you leave it for a while, the light may stop flashing and you can reduce the volume with the control. Other times, no matter what you do, it's uncontrollable with the control. Please note that the only part of the TV affected is the volume. I'd be VERY grateful for some help! the volume goes up by itself and stays at maximum and will not stay down. the tv is out of warranty by one day and parts are not available. is there any way i can use a home theater speaker system to control the sound? it has nothing to do with the remote. i am in canada thank you ruth I am in HK and have a Philips 42PF9831. Recently mine does the same thing as well, and sometimes it also switch the TV menu screen by itself. I have applied a newer firmware from the Philips website, but it does not resolve the problem. I don't have warranty anymore, is it a hardware problem? Can someone please help? Thanks.
2 Suggested Answers
  • 1879 Answers
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Posted on Sep 30, 2008
LG TV 32H3300 - volume increasing and decreasing by itself. It will increase if it was turned up via remote last and then will decrease by itself when volume is decreased via remote because it was too...
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
May 15, 2011 | Televison & Video
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
Toshiba volume increases by itself
This model do have a Remote Control right? Try to check that out... the remote could be the one setting the Volume up suddenly.
Mar 16, 2010 | Microsoft Windows XP Professional With...
Menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Sound on my Logik TV
change the memory of you is an IC with 8 pins near the front panel.if not working, change all the button switch
Oct 24, 2008 | Bush 5693D 24" TV
Volume and menu does not display
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Jan 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Philips 27PS55S/121 sound level decreases
Yes, the dynamic range on DVD's is enough to cause the high and low passages to be somewhat annoying but, sounds more like a movie theater. This kind of dynamic range showed up first on Beta HiFi and VHS HiFi VCR's because of thier range as well. If there is a feature in your audio menus on your TV such as "audio expansion, SRS, Wide mode, etc." turn it off and let the audio be processed without expansion of any kind as that will amplify your dynamic range alot more. The lock up issue could be something Philips is aware about and if under warranty contact them. Otherwise not much you can do except manke sure the voltage going to the TV is failry stable between 110 volts and 120 volts. Sometimes dramatic drops and or increases can cause lock up or confusion to the microprocessor in the TV.
Mar 25, 2007 | Philips 27PS55S 27" TV
Soyo DYLT032D 32 in. LCD Television Logo
476 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
