Question about Tomtom GO GPS Receiver
Tells me to get off at each exit
I put in my destination and when i start it tells me to get off at each exit. if i do this i will never get to my destination
  • 864 Answers
Did you accidently set your routing options to default to "Avoid Freeways".
Posted on Jun 03, 2009
How do I know how far a destination is
your GPS will tell you trip millage to destination before you move, after you put the address in. It will also update millage along the trip, and before turns
Feb 16, 2015 | Garmin nuvi GPS
I've been trying to use ocr on my Brother DCP-J315W and I get this error message: "Unable to write the file to Destination Folder. Please make sure that you have correct permissions to write to th
Where is the destination folder located is it windows .If Windows
Open file Explore (right click on Start icon select File explorer or explore) Right Click on Folder and check sharing permissions and allowed users.
Jan 03, 2015 | Brother DCP-J315W Inkjet Multifunction...
I have classic model KM-2030; need code to change paper size from 8-1/2 X 11 to A4. Thank you!
Setting the destination Description
Switches the operations and screens of the machine according to the destination.
Purpose
To be executed after replacing the backup RAM on the main PCB or initializing the backup RAM by running
maintenance item U020, in order to return the setting to the value before replacement or initialization.
Enter Maintenance Mode
Enter "10871087" from keypad, You should now be in maintenance mode.
Enter "252"press "Start / Print" key.
Select your destination from list on the display.
Press "Start / Print" key.
Enter 001 "Start / Print" key to exit to normal display.
Method
Press the start key. The screen for selecting an item is displayed.
Setting
1. Select the destination using the cursor up/down keys. The selected item is displayed in reverse.
Display Description
JAPAN METRIC Metric (Japan) specifications
INCH Inch (North America) specifications
EUROPE METRIC Metric (Europe) specifications
ASIA PACIFIC Metric (Asia Pacific) specifications
2. Press the start key. The setting is set, and the machine automatically returns to the same status as when
the power is turned on.
Completion
To exit this maintenance item without changing the current count, press the stop/clear key. The screen for
selecting a maintenance item No. is displayed.
Feb 09, 2011 | Kyocera Mita RADF-11 REVERSING...
I have a scan button but it always reads "usb not connected". It is connected and print. I have tried connecting it to several ports. I turn off the computer and restart. I turn off the printer and back...
Hi
To resolve this issue I need to know the operating system, but however as you did not provide it I will assume your operating system to be Windows XP and provide this below troubleshooting steps.
Solution:
Step 1.
Try copying form front panel and if copying doesn't work, check for the hardware issues with the scanner. If copying is fine then perform below steps.
Try scanning from Windows internal scanning drivers to confirm if the All-in-One is detected in the computer or not.
Step 2. Scan using WIA
To isolate the issue I suggest you to try scanning from the Windows Image acquisition (WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If the scanning is successful, proceed with step 3. If scanning was not successful then I request you to perform the step given in step 4 and then perform step 3.
Step 3: Manually check for Digital Imaging Monitor and populate the destination list
The digital imaging monitor must be running for the scan to function to work. The digital imaging monitor normally appears in the system tray in the bottom right-hand corner of the computer screen, next to the time.
If the digital imaging monitor appears in the system tray, go to the section Populate Destination List.
Please follow these instructions to resolve Scan from Front panel of All-in-One unit issue:
1. Click the Start icon.
2. In the Start Search text box located above the Start icon, type msconfig and then press Enter.
3. On the User Account Control window, click Continue. The System Configuration window displays. Click on the Startup tab.
6. Search the list for the digital imaging monitor, the file name will be hpqtra08.
7. Recheck the box for hpqtra08.
8. Click Yes to restart Windows.
NOTE: If hpqtra08 is not on the list in the Startup tab, this indicates that the driver was not correctly installed. Uninstall and reinstall the driver.
9. Populate the Destination List with following steps:
a. Open the HP Solution Center.
b. Click on Settings --> Scan Settings --> Button Settings.
c. In the window opened, select "Scan to button" tab
d. Click the Destination List tab.
e. Click on each of the programs you want to appear in the scan to list.
f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
g. Click OK.
h. Now try the scan to function from the all-in-one.
To save the above changes I request you to perform steps given below as Dest test.
Perform the dest test:
1. Close all applications including HP Solution Center.
2. Open and run the DESTTEST file from the location:
C:\Programfiles\hp\digitalimaging\bin\Under Destination:
a. (Optional) Set the Category for the Destination List scroll
down menu on WEB_APP.
2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
3. Click on Exit in the bottom.
4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
Yours Sincerely...
Roger
Oct 04, 2009 | HP Photosmart C7280 Printer
My F4240 will print and copy but wont scan
Hi
I am providing you steps for Windows XP if your O.S is other then please reply.
Solution ;
Try copying if copying is fine then Scan through WIA.
Step 3: Manually check for DIM
g. Click OK.
Oct 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I only get 2 choices in the scan menu what happened to the rest
Hi
As you have not provided me the O.S information I would still like to perform few basic troubleshooting steps.
Step 1:
g. Click OK.
Step 2: Perform the dest test:
For pictorial representation on these steps, please visit below URL:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00280633
Yours,
Roger
Oct 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
I am trying to put in multiple destinations for the same trip. When I try to put in my second destination it keeps going back to my home site not my first destination. It starts the trip for my second...
The Nuvi you have does not support multiple destinations in a route. you can have 1 destination and 1 via point. So if you are going to a destination and you need to add a stop in the route, you can add the 2nd point to go to and then continue to the original destination.
Feb 21, 2009 | Garmin Nuvi 350 Car GPS Receiver
Clearing a destination - TomTom One
To just clear a current route: www.tomtom.com/6998, if you want to delete recent destinations that you've navigated to, go to Main Menu > Navigate To.. > Recent destination > Delete.
Dec 21, 2008 | Tomtom ONE GPS Receiver
Removing previous destination
I hit Guan by mistake but meant to enter new york. How can I change it to new york?
Dec 26, 2007 | Tomtom ONE GPS Receiver
Fatal Error Message
I have an older one of these with the AV connections. once in a while it does not see GPS signals. If I exit navigation and from the main menu select setup, I can reset the GPS and then go back into navigation, this seems to cure the issue but it may return. I think the root cause is a low memory battery in the unit.
Nov 08, 2007 | Fine Digital FineDrive 400 GPS Receiver
Tomtom GO GPS Receiver Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
