Question about Dell 3100cn Laser Printer
DELL 3010cn printer reads 004-321 Restart Printer Reseat drum Contact Support. Restarting the printer, reseating the drum does not resolve the problem.
  • mark_kohls Jun 04, 2009
    This solution solved the problem! The description was a bit difficult to follow because the color did not match but I got the idea. Thanks so much. -Mark
    Genius:
  • 1,689 Answers
Hi mark,
here is a post from a user that made it work through fixya.
" I opened the front panel and lifted the lid. I found the blue tab on the right side and removed the drum I found the black rubber band which is hard to miss since it's the width of the drum. I noticed will turning the wheels that operate it that there was a silver plate embedded in the rubber and realized the rubber was not centered which causes improper reading of the silver plate. I pulled on the rubber to center it replaced everything and presto!! it worked."
please take note that this method does not apply on all 4-321 issues, here is another one...
" I HAD the same problem...a couple of posts up/down, someone suggest to re-align the film roll on the Drum. This worked for me. There are two wheels on the outer-side of the film reel (the film reel is one of two reels on the main top drum). Take out the drum, not the green reel, but the other one. Check both ends and you can se/feel two little silver metal wheels (again, at the ends). Roll the film around with your fingers until it is aligned evenly with the wheels. The metal on the wheels should not be showing at all, they should both be covered by the film reel. Replace the drum and cross your fingers. This worked for me...I'm sure a NEW drum would fix the problem, as well. "
bottom line is if the first post did not work, you may need to have your drum replaced.
hope this helps.
best regards,
voodoo
Posted on Jun 03, 2009
  • marlon john madrid
    marlon john madrid Jun 03, 2009
    mark
    here is a troubleshooter from Dell that will be very helpful for you as well.
    http://support.dell.com/support/topics/g...
    regards,
    voodoo
We have a Dell 3010cn printer laser and it has an error message saying "reseat fuser". We do not know what this means. Please help!
Hi
The "fuser" uses heat to melt the toner-ink onto the paper, to "fix" the ink to the paper.
Open the printer, remove the cartridge, and make sure that the fuser is _exactly_ "seated" into its socket. Replace the cartridge, and try againn.
Otherwise, take the printer to a qualified technician.
Jun 02, 2011 | Dell 3010cn Laser Printer
What is going on with my printer when it reads 'Restart Printer and reseat drum'?
hi
if you recently replaced the drum, you will have to remove and place it back properly
Jan 09, 2011 | Dell 3010cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
"009-362 Printer, Restart Printer, Reseat c cart., contact support"
The Cyan Toner Cartridge is either not seated correctly or the cartridge is bad. Open the front of the printer, pull out the Cyan Toner Cartridge, reseat making sure it fits all the way to the back.
If the problem is not resolved replace the Cyan Toner Cartridge.
Oct 21, 2010 | Dell Printers:Dell MFP Color Laser 3115cn
We keep getting the following message - restart printer reseat fuser
Jan 14, 2010 | Dell 3010cn Laser Printer
Dell 3010cn printer, says reseat drum contact support. I took drum out and put it back in but don't see anything wrong. It feels secure and I restarted the printer, but no luck.
Hello sir; Pull out the drum cartridge, look around the cartridge you will find a small memory chip, remove it, shoul d take care this problem.
Nov 28, 2009 | Dell 3010cn Laser Printer
Reseat drum dell color printer 3010cn
It means that you have to fix the drum,(ie the long cylinder that contains powder in the toner properly)
Jun 01, 2009 | Dell 3100cn Laser Printer
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Dell 3010cn DRUM
The information I have on that error is as follows:
From the Dell TS Guide:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=04&journalid=4D4C014288160766E040A68F5A283437&l=en&s=bsd&treeid=DCD92482F5548BF9E030A68F27281FC1&Query=ZHJ1bStlcnJvcg==&SystemID=PRN_LSR_3010CN&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
1. Replace the cartridge with a new Dell Branded one
2. If cartridge doesnt resolve, replace the left Intermediate Belt Transfer (IBT) guide assembly.
3. If that doesn't fix, replace the Machine Control Unit (MCU)
May 15, 2008 | Dell 3010cn Laser Printer
Dell 3100cn Laser Printer Logo
297 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
