Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Mower won't start
Mower was cranking slowly then would eventually start if I was jump starting it. battery went bad replaced battery and starter, mower won't start, starter not even cranking?
  • 59 Answers
Sounds like the ground cable is bad
Posted on Jun 26, 2009
I bought a 2000 savana van. never had problems starting, I jumped a relay once to get it started, then it continued not cranking, A friend came by days later to take a look and it turned over and...
I would replace the starter and /or battery. Both can be checked at a parts store. Sounds like you may have a short in the starter, draining the battery.
Feb 12, 2015 | 2000 GMC Savana
Why won't my 2012 Suzuki Grand Vitara start?
ill answer for NO ELECTRICAL POWER :
sure and is easy with any DMM meter, got one? any $20 DMM.
my guess;1
engine will not crank
dash lamps out.
head lights out. dead.
post systems of electrical system , all parts that work and those that dont work, and problem is easy.
cleaned battery terminals.
tried borrowed battery that reads, 12.6vdc ? (charged is 12.6)
2012 that is in warranty car.... ?
my guess on 2012
jumping a car, that is battery jump starting.
a battery can short, and no jump start on earth will start shorted battery in car. but does lay down some big sparks, or burns up cheap walmart cables.
if the car will not crank, say just that, my starter motor will not crank
jump started from live running other car.
if true then make sure headlights work , if they dont work fix that first.
HL must always work, even keys in pocket.
best is to put a fully charged battery in the car, jump starting can cause
surges that can damage sensitive electronic$$$, do jumps as a desperate measure,
with a charged battery,
1: Head lights work, no fix that , use voltmeter
2: cranks robustly.
no , wiggle shifter lever, (on A/T cars the park switch blocks cranking) On M/T the clutch blocks cranking.
with any dMM
measure battery voltage before crank and during.
12.6v good. reseted.
cranking.
0 to 10v bad (weak battery or shorted starter motor)
11 and above good. and must crank, if not , starter is bad.
to prove starter is bad, check voltage at starter solenoid coil wire lug.
it must be at 11v cranking , below 8v it chatters, and fails.
if at 0v cranking this lug that means the Key start line is failing.
A/T switch not closes, or bad ignition switch.
May 25, 2013 | Suzuki Grand Vitara Cars & Trucks
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
I jumped car off it crunk on its own fora day,then batt went dead again,this time it won't jump off. It wants to crank but won't turn over.
not sure what you said but.
seems the battery is discharging,? 12.6v is fully charged,
own a voltmeter?
try a good loaned battery , does it start the car,?
i think you meant?
i can jumper cable start my car at any time. (off another running car)
but after running my car, the battery discharges and it will not crank at all. right?
this means ,the charging system on your car is bad.
if the starter cranks great, then the engine is flooded or is in great need of a tune up (sparkplugs etc)
if flooded try the super secret in the op guide, crank with throttle wide open , this magic trick cuts all fuel injection allowing the flooding
to purge away, and eventual starting.
my guess 2 is the car wont start, so you crank the battery flat
you jumper start it and it runs. (luck)
then day 2, same deal cranks ok but wont start.. ever tune up the engine?
Feb 08, 2013 | 2007 Suzuki Forenza Sedan
My craftsman yt1000 23bhp, i have been jump leading my mower for around 6 months now, i started my mower last night no problem but got up this morning, turned the key and it just buzzed. so i origonally...
check the solenoid if you been jumping it off you could have burned it out and possibly the starter replace the solenoid first thats the cheap route and if that dosnt fix it check the starter if its buzzing or clicking its gone bad feel if it get hot if it does thats the bad sign to look for, replace solenoid, then starter thats my advise need more info messege me back for more, thanks, jamie
Dec 27, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mower ground wire heats up. Mower won't start.
try and jump start it direct to the starter if the cables are weak they will get hot and it the starter is bad they will as well this will isolate the cause
Apr 26, 2012 | Garden
Won;t crank
Hi, if the car engine fails to crank, there is a fault in one of the components in the battery/ignition/starter circuit. Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger). Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay). Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
May 26, 2011 | 1994 Dodge Stealth
Last week, my 1998 Lexus ES300 wouldn't start (clicking sound) and I thought it was the battery. I jump started it but noticed that it still made the clicking sound, for my first couple of tries, it did...
If car wont start and clicking sound is heard this is a battery related or starter related, if your car battery is in good condition (which I think it was) then the problem is your starter, have it check to confirm.
Aug 17, 2010 | 1998 Lexus ES 300
Hello, f150 hard time cranking then fried some circuits no power
You said it wires solenoid Starter. I would start with the starter and the solenoid
Sep 27, 2009 | Ford F-150 Cars & Trucks
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
549 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
