Question about Insignia 720p Widescreen LCD HDTV
I dont have continuous reception (picture is fragmented pixals)
Well its like the antenna isnt picking up a continuous signal and it causes the picture to stop and be all fragmented. You must have seen this ,?when the pixals just go nuts?
  • 864 Answers
Digital TV will do that when antenna does not receive sufficient signal.  You may need a different antenna or have to aim your current antenna differently. Go to www.dtvanswers.com for more info.
Posted on Jun 03, 2009
My vizio is set on avor antenna I have a HD antenna but TV won't pick up my favorite network stations wtva om nbc or abc
re-orient your antenna , the more the higher the better signal reception you will receive. and check your neighbor tv reception if they are facing the same problem with your tv , the problem isnt with your tv, its the tv network sometimes failed.
Nov 29, 2016 | Vizio Televison & Video
My son used the cord from a kettle for our LG plasma TV (we cant find the TV cord) it isnt working properly. The pixals breakup. I said we needed a audio/video specific cord.Is that right?
Hi if the cord fits the kettle and the television then great, They both run off the same electricity current meaning the electricity won't harm television or cord... Smart kid :)
Mar 19, 2016 | LG Televison & Video
Chanel abc picture fragments
Assume you are using antenna, not cable or sat for signal.
abc signal is too low causing break up.
Reaim antenna for better reception.
Go to antennaweb.org website which should help you aim for best signal.
Feb 18, 2013 | Televison & Video
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
Nov 07, 2011 | Car Audio & Video
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
I hooked an antenna up and can't get a picyure!
I assume you have tried to retune the TV & angle the antenna in different positions. Very often, due to the location of your home & the strength of signal in that area, you usually find that , no matter what you try, an indoor antenna is just not strong enough to pick up in a weak reception area. The only alternative is to try & add a signal booster onto it or much better still ( and a lot less future reception problems) is to rig up an outdoor antenna.
Sep 01, 2009 | JVC AV-32D305 32" TV
I have an RCA DLP tv and it is on an antenna attached to the house the mast kind. I guess what I want to know is the picture comes in fine but then the picture breaks up or freezes. I am guessing it is...
You are correct in saying that it is a signal issue. There is not a lot you can do about it when using a outside antenna. You should be getting the best quality HD but you will always be limited by the reception. Since the HD signal is broad casted across the UHF spectrum, you may want to change the type of outside antenna you have to a UHF/HD type.
It will be a cost but the only other thing you can do is to get cable installed and that will also be a cost also.
Hope this helps,
skyassoc
Jul 16, 2009 | Televison & Video
Dont not pick up freeview channels
if u pick up NON freeview channels, i think the antenna isnt good enough to pick up the signal..freeview requires a very good signal, very important.
If you think this isnt the problem rescan the channels
If you think the TV is faulty contact Samsung directly
Jul 15, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
Insignia 720p Widescreen LCD HDTV Logo
351 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
