Question about Panasonic Microwave Ovens
Microwave seems to work but does not heat food
Microwave looks like it's working, lights come on table turns usual humming noise, but does not heat the food and after a while shuts itself
  • 6,784 Answers
OK, you may have a damaged thermostat or, the Magnetron may be damaged as well. you can test each device with a meter(ohm,volt).
replace any parts that dose not register.
Posted on Jun 03, 2009
  • Michael Masters
    Michael Masters Jun 03, 2009
    You should really test these parts before you make a decision that they are in good condition. you cant tell by looking.
  • Michael Masters
    You stated that your microwave dose not heat, the Magnetron is responsible for the heating of the contents. it is obviously NOT working.....
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
Wont heat. Everything else seems to work. I notice a HUMMING noise while it is opperatiing
A loud humming or buzzing noise would indicate a short on the magnetron circuit, the part that heats the food. These can be expensive to repair since the cost of the magnetron can be as much as a new oven. Get a few estimates before deciding whether to repair or replace.
Dec 07, 2010 | Whirlpool GH4155XP Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Microwave does not heat. Strange noise coming from motor. Everything seems to be working but does not heat food at all. Loud buzz or hum coming from unit.
You may have either a bad filament transformer or a bad magnetron tube.. and if you are referring to a table top model .....then the cost to repair may be more than the cost to replace.. so consider that into your decision.. Table top microwaves are relatively inexpensive now..
If you are referring to an over the stove combination micro/vent system then you may want to get it repaired by a certified appliance technician. There is high voltage inside the electronics compartment and by opening the cabinet, you may not reassemble it correctly and compromise the shielding in which case you may be exposing family members to microwave energy... Not good..
Hope this helps..
Sep 17, 2008 | GE Microwave Ovens
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
Microwave Ovens Logo
247 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
