Question about Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37MF231D switches off and back on every few minutes
Our Magnavox 37" turns itself off when the room temp reaches about 68 degrees, it comes back on after about 5 seconds but will do this continually unless we keep a fan turned on behind it, this started happening after about 6 months of ownership, we have to use the fan to cool it all the time now and the noise from it practically drowns out the audio on the TV, plus if the room gets hotter than 80 degrees or so running a fan behind the TV is ineffective. Any solutions out there? Thanks.
  • brightwellho Jun 03, 2009
    Hi, its not under warranty anymore, this started happening a week or two after the warranty expired. The fan is not part of the unit but a table top fan we had to put behind it separately and it works fine on it's own just the noise is annoying. I believe the TV needs a capacitor replaced but I don't know which one, where to get it, or who can install it. Thanks,
  • 13,433 Answers
Its definitely a overheating problem, if the fan on the television is loud you need to replace the fan(s) with a new one. it will also improve the airflow possibly get it back to normal so you might not need the fan behind the tv.
If you are on warranty, note that replacing the part will most likely void the warranty, you could ask if your dealer or the company could warranty repair it for you.
if you are outside of warranty you could replace the fan with a matching model or with one that fits and has the right voltage requirements etc. You need to look at the old fan to find out its voltage etc. possibly even model reads on it.
If the unit is on warranty its definitely best to send it in for repair, you don't have to worry about repairing it yourself.
also working inside a television even when unplugged is potentially dangerous as some components may hold voltage even when the set is unplugged!
Posted on Jun 03, 2009
  • Ekse Jun 03, 2009
    if the unit does't have a fan, well, it shouldn't require a fan behind it. I think its unlikely to be one capasitor or two, I think you better take it to a local professional that can test and find out what is causing the overheating, capasitors may be involved but its unlikely to be the only cause.
"I have a White Rodgers 1F78-151 thermostat and for some reason the system keeps shutting off every few minutes and never reaches my desired temperature i constantly have to set it to off than back to
Is this a gas fired furnace? If so it may be going off because one of the safeties is tripped. There is a high temp safety that will shut the unit down when this temp is reached. The usual cause is low airflow. Check your filters, if these are OK you may have a blocked coil which should be professionally cleaned.
Feb 01, 2015 | Heating & Cooling
Per magnavox 37mf231d I switched tcon board, and put an older main board that I had laying around, now the tv tries to turn on, there is a background light for about 5 seconds and then it shuts off.
Hello, I think it either had a bad back light board or one of the florescent tubes in the display has gone bad. As these sets get older, I see more of the florescent tubes going bad. I think there are 9 in that set, and all it takes is one of them to go out to cause the set to shut down. You may also look for a bad connection on the transformers on the back light board.....thanks, let me know
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
Magnavox 37" model 37mf231d-37 wont tun on when i hit power button the screen lights up for a secongd and turns right back to black and the power button green light comes on and right back off I found
Your power supply is weak. If you think you can repair this I will tell you how. If you cannot do this,find someone who works electronics and share this repair. Two capacitors are bad. When pulling the back cover off, you may see one or two capacitors bulged. Even if they look good....replace these capacitors. The locations are numbered and, the capacitor having a value and temperature of 105 degrees.. Location of the first capacitor is 2074, value 25volts @ 2200 mf @ 105 degrees and will most certainly be bulged. The next capacitor may look fine....replace it. That capacitor location is 2066, value is 35 volts @ 1200mf @ 105 degrees. When you replace these, please be sure to get the polarity (positive leg and negative leg) of these capacitors seated correctly...this is a must. This will correct your TV. You will save lots of money, because you asked. Thanks for listening ..good luck...we will be here for your next repair.
Jan 02, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
Tv turns on and off i can hear it come on and see a flash of light but five seconds later it shuts back off.
You have two bad capacitors...a 25volt 2200Mf 125 degrees and a 35volt 1200Mf 125 degrees. I think the degrees are correct..be sure to check this out. It will be on the cap itself...been a while since I repaired one of these. Locations I beleive are C2074 and C2081. Good Luck and reply with your rating!
Jan 07, 2010 | Philips 37MF231D 37 in. LCD Television
I have to play with thermostat to get my heating system on
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Dec 11, 2009 | Goodman Heating & Cooling
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
The thermostat does register the right temperature.
Your heater might be on the Auto settings .. it will turn on and off itself once the pre set temp is reached ...
Jan 05, 2009 | Lasko 5365 Ceramic Compact Heater
Heater shuts off as soon as the room is warm
I take it once the temp is set to 71, and the ambient temp reaches 68 or so, it shuts off, never to come on again?
If that is true the thermostat in the unit is damaged, worn out or in need or replacement, but try a couple tricks.
First, if there are access panels to clean, clean it per the manual, it could be that a dirty filter or air inlet is confusing the thermostat.
Next, unplug the unit for at least 5 minutes, try it again.
Next set the unit on it's highest temp and blower setting, let it rip for 20 minutes, shut it down, unplug and remain unplugged for 5 minutes.
Next set the unit at 71 HIGH MODE.
see if we have a mode switch problem or thermostat if it works on high mode, it is not the thermostat, but I imagine it is, but I am curious as to if it once goes off, it never again comes back on?
Will
Dec 01, 2008 | Bionaire BCH-4138 Ceramic Compact Heater
Toymax Magnavox 37MF231D 37 in. LCD TV Logo
125 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
Paul
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
