Question about Microsoft MS Xbox 360 Common Controller (DHC8G00004)
Xbox 360 Controller for Windows causes fuzzy sound
When i plug this in it makes my sound all fuzzy and wont go away until i restart my pc with the controller unplugged
  • 12 more comments
  • code1001 Oct 25, 2007
    I need to figure this out. this is ruining the reason why ibought my new computer help please!
  • Anonymous Dec 07, 2007
    exactly the same problem here. as soon as i plug in the usb controllers my usb headset starts acting up
  • KingDaDeDe Dec 28, 2007
    I have the same problem, but I already have a Creative SBA, so that won't fix my problem. What can I do?
  • moodinsk Jan 02, 2008
    Same problem with no response from M$ about the issue...
  • seb99 Feb 07, 2008
    when i plug my xbox 360 wired controller in, it disables all sound from anywhere on my computer untill i unplug it. which makes it crap for playing san andreas on pc because you cannot hear anything, plus the 4 buttons on the back of the controller do not work,making the controls of the game nearly impossible to configure. Am i the onlt one with this problem?
  • Anonymous Feb 09, 2008
    i have the same issue, it was driving me crazy because i couldnt figure out what it was and bought a new headset before figuring it was the 360 controller driver.
    anybody have a recommendation?
  • Anonymous Feb 12, 2008
    Windows x64. I plug in the controller and the sound through my USB headset becomes fuzzy and distorted. Unplugging the controller does not help. I have to unplug the controller and reboot the machine.
  • idlebyname Feb 17, 2008
    When i try plugging in either the X-plorer controller or the standard xbox 360 controller my mic gets distorted nothing seems to fix this untill i do a systems restore even manually uninstalling the drivers doesnt fix this whats going on? i`m using 64bit Vista.
  • ocphox Feb 26, 2008
    I have an Creative SB X-fi sound card and that definitely doesn't fix it, in response to one of the below "solutions."
    All it does is ruin my mic input. It's really annoying and it shouldn't be messing with my audio-in unless I tried to install the stupid Xbox headset to go with it.
  • Anonymous Mar 08, 2008
    I also have the same problem when I plug in the Rock Band Guitar. It must have something to do with conflicting USB devices. I have tried to contact logitech, microsoft, and rock band, and I have not gotten a response from any of them. GREAT customer service....
  • Anonymous May 27, 2008
    i installed a creative soundblaster card and the issues with sound are now resolved- hope this helps.
  • kaganedu Nov 19, 2008
    same problem for me.
    if i plug in the xbox 360 controller, my external usb sound card cuts out.
    i have to unplug the xbox 360 and reboot to get the sound back.
  • Anonymous Jan 27, 2009
    i have the same problem my headset makes a fuzzy noise when ever i play Xbox Live evry1 hears it and i barley play anything i've tried YouTube but none of thr methods work my headset is wired and i do not have a computer hooked up to it i have the Xbox Live adapter
  • ocphox May 11, 2010
    I HAVE a Creative sound card, and it doesn't work. Definitely not a fix for it.
    Ctrl + Alt + Del'ing the procses didn't fix it either. Really retarded. What a horrible product this controller was. I'm probably going to mail it back.
    Creative SB X-fI Extreme Gamer card
    Logitetch AK5370 Desktop Mic.
    Only messes up my audio-in, I am guessing because of the Xbox 360's controller possible audio input with a headset or something. Really, really annoying overlooked problem courtesy of Microsoft.
Found a solution! Came here to post it, since I could not find the solution ANYWHERE on the internet...
Using an Xbox 360 controller or any other Xbox 360 peripheral with 95% of USB sound cards or headsets will produce HORRIBLE sound input and output. It sounds like a robot has swallowed and spat back out the waveforms. Even if the 360 peripheral is removed any USB audio devices plugged in after the fact will still sound corrupted until a fresh reboot without the 360 peripheral plugged in.
I believe that the problem is somehow linked to the "generic root hub" driver, which hasn't been updated since 2001, thanks M$.
The solution (pick one of 3):
As long as the 360 peripheral is on it's own internal virtual root hub it will not interfere with other devices. You can force it to use another root hub by doing ONE of the following:
1) Fill up your usb ports with other devices till it shifts to using a secondary root hub, then plug in the 360 peripheral. This could take up to 10 USB things, depending on your motherboard and the maximum devices on each root hub.
2) Use an extra internal PCI-USB card for the 360 peripheral.
3) Use an extra external USB hub for the 360 peripheral.
NOTE: A reboot is usually required to clear up the driver's confusion.
Posted on Mar 20, 2008
  • Tutoh Feb 07, 2011
    I had the same issue with a seat of Logitech G35 headphones while using a XBox360 controller. I tried the PCI USB, which didn't work, but then I borrowed a Lindy USB 2.0 4 port Sharing Hub and connected the controller alone to that, no DC power connected to the hub. The sound is working fine now.
  • 28 Answers
DEFINATE SOLUTION!!!
Go to your sound properties...
Control Panel>>Sound and Audio Properties>>Audio Tab
Check the "Use only default devices"
APPLY
Plug in your controller and everything works normal!
=P -D.D.S.
Posted on Feb 05, 2009
Same problem here. I just bought this controller a few hours ago, I updated all my drivers and everytime I plug in the controller, the sound gets all messed up. Only way to fix it is to restart the computer without the reciever plugged in :(
I read on another forum (cmedia.com) that other people who had the same problem are going out purchasing Creative sound cards. I really hope this isn't the only solution, I've already spent $60 on this controller, I'm not going to spend any more just to get it working...
I'm starting to regret the fact I didn't stick with the Logitech gamepad :(
Posted on Dec 20, 2007
I plugged a usb hub and no more sound fuzzy
im on vista ultimate x64
Posted on Oct 17, 2008
Maximina you are the man. I don't know how you found out do'n this would work but it did for me!!! I was running vista 64 but recentally went back to vista 32 due to quicktime issues. But I did what "Maximina" said. I pluged in almost every USB device I have, and the last one open I used for my XBOX controller. WOW no more distorted noise!!! Now I don't know if I have to do this everytime just wanted to let you all know this worked for me. As far as headsets go, I'm not sure on that issue. Again thx Maximina!!!
Posted on Apr 10, 2008
Did you install the Xbox 360 for windows download you can get off the microsoft website 'cos i use the controller and have no probs at all
Posted on Oct 16, 2008
    Getting a simple 4 port shared USB hub fixed this for me
I have just fixed it.... I think!
Try closing down the xbox process that is running on your pc with control and alt and del. End the process before you plug it in (Only way I have tried so far) and my sound is now working with out any distortion.
Posted on Feb 15, 2008
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
Xbox controllerwirless wontconnect to pc
To connect the controller to a computer that is running Windows XP SP2 or a later version of Windows, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that the Xbox 360 Wireless Gaming Receiver for Windows is plugged in to your computer.
  3. On the Xbox 360 Wireless Gaming Receiver for Windows, press and release the small round Connect button.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. The Ring of Light on the controller spins and flashes one time, and the light on the Xbox 360 Wireless Gaming Receiver for Windows flashes. When the controller is connected, the Ring of Light on the controller remains lit and indicates the position in which the controller is connected.
Note If you want help connecting an Xbox 360 Wireless Controller to your personal computer, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
Jan 07, 2010 | Microsoft Xbox Console
Xbox 360 Wireless controller wont turn on
Right, just keep plugging in the charger into the controller until the light stays red, the small amounts of charge put in each time will eventually give the battery enough juice for it's built in 'memory' to be clued in as to how much power is really in and will then start charging. This is usually caused by leaving your controller unused for a while usually days or so at room temperature after fully charging it in your xbox (i.e. the battery memory 'thinks' it's full and tells the xbox as much when really it's empty)
Jul 04, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless controller wont work unlessed plugged in
May 06, 2009 | Microsoft Xbox 360 Controller
Xbox 360 guitar hero 3 controller [wired]
try restarting your xbox, make sure your controller is properly connected, and try replacing the battery.
Aug 01, 2008 | Microsoft Xbox 360 Controller
PC sound problem when using xbox360 controllers
I should have fished around a bit more before posting that I have the same problem.
Go into your control panel
Double Click the "Sounds and Audio Devices"
Select the "Audio" tab
It will show that your "Sound Playback" and "Sound Recording" default device is set to "Headset (XBOX 360 For Windows)" in the drop down menu
In that same drop down select "Sigma Tel Audio" or what ever your regular default is
Click the check box at the bottom left of the window that states, "Use only default devices"
Then click apply and viola you should be able to use your 360 controller with your pc sound
I'm only guessing here, but if you want to use the 360 headset you may have to change these settings again.
Dec 31, 2007 | Microsoft Xbox 360 Controller
Xbox 360 Vontroller makes my audio fuzzy
same problem here. searching for a solution to this problem is like running around in circles. I'm getting to the point where I'm about to go out and buy a decent sound card and hope it works. If it doesn't I'm going to return this POS and go back to good old Logitech equipment.
Oct 24, 2007 | Microsoft MS Xbox 360 Common Controller...
Fuzzy sound when plugged in
The Problem is C-media doesn't have proper driver support. It seems to be the on board sound card. The only real fix is to get a different sound card. Hopefully c-media will eventuall address the problem in a new driver.
Oct 24, 2007 | Microsoft Xbox 360 Controller
Microsoft MS Xbox 360 Common Controller (DHC8G00004) Logo
4,476 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
