Question about Car Audio & Video
The unis a Clarion AM FM Radio / CD Player.in a Holdewn YG Cruze, all wheel drive vehicle. Radio is stuck on channel 693 with a small M1 appearing on bottom right hand corner of screen. CD unit is working but unable to switch CD menu. Clock is working OK. Sound quality is good and volume and sspeaker controls work OK. No improvement or change when BND Button, Ps, FNG buttons pressed. I would appreciate any help. Thanks Don Malcolm email don.malcolm@bigpond.com
  • 1 more comment
  • don_malcolm Jun 03, 2009
    Thanks, I am unsure of how to remove unit to check model Number.
    Specifications are:-
    Security code
    Am / Fm Radio Bands-1AM 3FM
    18 FM, ^am Touch button Memory
    Seek UP /down and Manual Up/ Down Radio Tuning Modes
    Radio Preset Station Scan (PS) and automatic station (AS)
    built in Auto Loudness
    Treble Base Fader Balance controls
    Scan Play
    Repeat Play
    Random Play
    Backwards / Forwards Music Search
    10 Track Programmable Memory
    Digital Quartz Clock
    Max Power output 120 W (30WX4)
    Hope that helps.
    Cheers
    Don
  • don_malcolm Jun 04, 2009
    Thanks Spark9.
    As the unit is factory installed unit it is difficult to check all wiring. I guess we will just have to stick with it for now and have the dealership check it out at next service.
    I had hoped for an easy solution like a stuck switxh that may be easily released.
    Cheers
    Don.
  • don_malcolm Jun 05, 2009
    Thanks for your suggestions.
    All buttons seem to be functioning Ok but not responding or allowing change of channel or from AM to FM.. Seems to me like a bad internal connection within the unit which will need service technicians help or replacement whichever is cheaper.
    Thanks to all for your help.
    Cheers
    Don
  • 3,267 Answers
It seems that this station mas replaced all the other station frequencies and has all the memory settings oat this particular channel.If you remove the radio from the bracket look for a pinhead sized rubber coated button with a slight depression n the center. Use any pointed object like ball-point tip, making sure that its not very sharp. Press gently till yu feel the pont comig in contact with a hard object. That is the reset button for the radio, just like Scientific calculators or small notepads *** planner *** clculator. By pressing that button will force the radio to go back to its factory default settings. After that use it as you normally would............................................................sodeep
Posted on Jun 05, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee Jun 05, 2009
    Please post the result as a comment so that I can follw-up since u have alrady consulted so many experts!...........sodeep
  • Sudeep Chatterjee
    Sudeep Chatterjee Jun 17, 2009
    Check the mike for the set. It might have been accidentally set at mike position. Thus its not responding to any other functions. If you can cancel the mike status by pressing the mike button again till it releases itself, then your radio will work normally..............................sodeep
  • 378 Answers
Try to press back the # 1 button, M1 means that memory 1 or press #2 if still no improvement. I assume that one the button is stuck ( continuously pressing). you can check it by pressing all button one by one, good switch or button will sound click every time you press you can hear it by moving your ear near to the switches. If there is jam switch or bad sw. you can't hear this click sound. Once you identified the problem simply change the defective sw.
Posted on Jun 04, 2009
    Novelist:
  • 151 Answers
M1 error is for internal mic in the radio has faulty or loose wiring.that has to be checked and replaced.if wire is loose then it has to be reconnected and if the wire connection is faulty then replace the wires. thanks.keep updated.
Posted on Jun 03, 2009
  • 13,433 Answers
Hey
Need to know more about the radio, could you be more spesific about it, brand is Clarion, do you know a model? might need to remove it to see the model.
How to remove cd stuck in player
Remove cd player and insert small tool to release stuck cd. Otherwise dissassemble cd player and remove.
Take to audio store and have them reome the cd.
Mar 20, 2015 | Jeep 2006 COMMANDER Radio a1z115973...
Wich video format supported
Released 2 years ago Included Units Stand-Alone Monitor, Amplifier
Supported Audio Formats MP3, WMA
TV Tuner Without TV Tuner
Radio Tuner AM, FM, Satellite, XM Ready
Aspect Ratio 16:9
Input Connectors AV x 1
MPN MAX685BT
Monitor Size 7 inch
Output Connectors AV x 1
Power Per Channel 50 Watts x
Supported Media Types DVD Video, DVD+R, DVD+RW, CD-R, CD-RW
Supported Video Formats DVD, DivX
Dolby Digital / AC3
I found all of this at http://wize.com/car-dvd-players/p469604-clarion-max685bt
Good luck.
Hope this helps!
Jan 21, 2011 | Clarion MAX685BT Car DVD Player
Hello, I have had a CD stuck in my Clarion DB345MP car stereo, when I press eject, I listen a noise but nothing happen. The radio is fine. Somebody help me.
the cd mechanism itself is probably bad and needs to be replaced. not ejecting is a common problem with that model of radio.
Jan 15, 2011 | Clarion DB345MP AM/FM CD/MP3 player
Set clock on m2455 radio/cd
since i don;t know which version you have of that unit here is a link with manuals just pick the version and it will tlel you how to set your clock.
Clarion
Mar 26, 2010 | Clarion M255 AM/FM Marine CD Player
Trying to set up satellite radio function on my clarion dxz755mc
there is more than 1 channel you can set to on sirius try setting your fm to 108 and set siriuus to same if you go into yor sirius tuner you can use the up and down arrows to tune in the stations
Dec 30, 2009 | Clarion DXZ755MC CD Player
I have a chrysler sebring, and my cd hot stuck in the radio cd player
a very small pair of very long nosed needle nosed plyers will get it out but will probally ruin cd
Nov 03, 2009 | Clarion DXZ545MP CD Player
CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Does xm on the clarion xmd1 am/fm cd player stand for xm radio?
no. there will be an authentic XM label on this radio if its compatible.
Mar 14, 2009 | Clarion XMD1-RET CD Player
Car Audio & Video Logo
185 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
