Question about Mitsubishi WS-55805 55" Rear Projection Television
Upgraded DirectTV satelite TO HD
THE  Direct TV HD  unit has a different output than the previous one,---what adapters can I use?
  • tvrobert Mar 02, 2008
    Thanks for your reply.
    We have looked on line and at every
    electronics store in our area, and
    cna't locate an adapter. Do you
    have a site that has this adappter?
Direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Posted on Mar 01, 2008
I am getting no audio from a set we purchased in Dec 2010. We have Direct TV Satelite and I truobleshooted with them and they believe it is a television issue rather than satelite. There is no sound at...
If the symptoms remain the same in all inputs like in the DVD player, then this is an indication that the fault is on the TV itself. It is caused by faulty audio/sound output circuitry in the main board. Since your unit is only 9 months old, it is still under warranty period. Avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 24, 2011 | Vizio M260VA 26 in. HD-Ready LCD TV
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
Jan 27, 2011 | Samsung HTC5500 Theater System
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
Cannot use the direct tv remote to control the volume, on / off, etc.
I have directTv and an olevia TV, and DirectTV remotes do not support Olevia
Jul 25, 2008 | Televison & Video
Getting tv to work on satelite
Most programmable remotes will work some combo units like yours,but,unfortunately,not all! The Direct TV guy is most likely right.
Sep 29, 2007 | Philips Magnavox 27MS343S 27" TV
Mitsubishi WS-55805 55" Rear Projection Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
