Question about Microsoft Xbox 360 Controller
Fuzzy sound when plugged in
My controller makes my sound all fuzzy in every program and wont go away until i restart my pc with the controller unplugged. what do i do!
  • 5 more comments
  • WarLordBael Nov 08, 2007
    I have the exact same problem. I'm running windows vista 64-bit with an Asus M2n-plus Sli Vista motherboard. I've tried updating drivers for my sound and xbox 360 accessories.
  • Cozzzmo Dec 13, 2007
    Yes. I do. When I plug it in the sound gets distorted. Any solutions?
  • Anonymous Jan 06, 2008
    have found out that most wireless driver shave the same affect on the sound on my pc
  • Anonymous Jan 10, 2008
    i have some problom
  • Anonymous Jan 13, 2008
    Did anybody ever find a fix for this? I have same motherboard and same problem!
  • janneh1 Jan 20, 2008
    I have same problem and same motherboard, so annoying all i wanna do is play pro evo but my ps2 adapter hasn't got any drivers for vista and my 360 controller distorts like you guys! Are you all running on vista too? Anyone got a solution yet? Has anybody tried asking microsoft?
  • 2sly Feb 18, 2008
    I have a ASUS-SLI running vista 64 and get the messed up sound as well. I have to unplug the controller and restart. Plz does anyone know how to fix this?
The Problem is C-media doesn't have proper driver support. It seems to be the on board sound card. The only real fix is to get a different sound card. Hopefully c-media will eventuall address the problem in a new driver.
Posted on Jan 23, 2008
OK, so for people with the same problem as me(sound routing through the controller), go into settings/control panel/sounds, speech, and audio devices/sounds and audio devices, and change the default output from the 360 controller headset to SB Live! Wave Device, or whatever you're using. Sound returns no problem, and I can use my original headset.
As for fuzzy sound, there might be some solution in these settings.
Posted on Feb 07, 2008
Well, not really a solution, but I have a similar problem. The sound disappears when I plug it in, but if I disconnect it comes back. SO I tried plugging the headset that came with my 360 into the controller, and I could hear the sound.
I don't like the 360 headset though, as it's just 1 earpiece and kinda uncomfortable, but I'm guessing I can play around with my comps output settings a bit.
At least for some the problem seems to be the sound just gets routed through the headset.
But i have a sound blaster audigy card and i still get the distortion!
2 Suggested Answers
SOURCE: Xbox 360 Controller for Windows causes fuzzy sound
Found a solution! Came here to post it, since I could not find the solution ANYWHERE on the internet...
Using an Xbox 360 controller or any other Xbox 360 peripheral with 95% of USB sound cards or headsets will produce HORRIBLE sound input and output. It sounds like a robot has swallowed and spat back out the waveforms. Even if the 360 peripheral is removed any USB audio devices plugged in after the fact will still sound corrupted until a fresh reboot without the 360 peripheral plugged in.
I believe that the problem is somehow linked to the "generic root hub" driver, which hasn't been updated since 2001, thanks M$.
The solution (pick one of 3):
As long as the 360 peripheral is on it's own internal virtual root hub it will not interfere with other devices. You can force it to use another root hub by doing ONE of the following:
1) Fill up your usb ports with other devices till it shifts to using a secondary root hub, then plug in the 360 peripheral. This could take up to 10 USB things, depending on your motherboard and the maximum devices on each root hub.
2) Use an extra internal PCI-USB card for the 360 peripheral.
3) Use an extra external USB hub for the 360 peripheral.
NOTE: A reboot is usually required to clear up the driver's confusion.
Posted on Mar 20, 2008
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
sounds like hard drive is bad, replace with new or buy new computer
Jan 09, 2013 | Acer Aspire Computers & Internet
I have a RZC 298W RCA FM/AM tuner/stereo amplifier that I cant find anywhere. It works ok, except its fuzzy. I'm Just curious about schematics and what year it is. it looks like its at least 40 years old....
You could contact a tv repair shop, many shops have schematics that go back many years. You say the sound is fuzzy, is this fuzzy sound when your playing the radio or when you play something throgh the amplifer? If its fuzzy with any source the you might have a bad speaker or speakers. you need to be more discriptive of the fuzzy sound you describe. also. if this unit has a head phone jack, (which I doubt if its 40 years old). you could plug in some head phone and see if the sound is clear there, if so then you know its most likely the speakers.
Mar 14, 2011 | RCA Audio Players & Recorders
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
When I move the The laptop screen turns green and fuzzy
Restart the notebook and press F10 to enter into BIOS which should be blue in colour. The move the laptop and check if the screen turns green and fuzzy.
If the screen turns green and fuzzy in the BIOS, then the isuse might be hardware malfunctioning of the screen and your notebook needs to be repaired.
Jun 08, 2010 | HP Compaq Presario CQ50-110US Laptop
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
PC sound problem when using xbox360 controllers
I should have fished around a bit more before posting that I have the same problem.
Go into your control panel
Double Click the "Sounds and Audio Devices"
Select the "Audio" tab
It will show that your "Sound Playback" and "Sound Recording" default device is set to "Headset (XBOX 360 For Windows)" in the drop down menu
In that same drop down select "Sigma Tel Audio" or what ever your regular default is
Click the check box at the bottom left of the window that states, "Use only default devices"
Then click apply and viola you should be able to use your 360 controller with your pc sound
I'm only guessing here, but if you want to use the 360 headset you may have to change these settings again.
Dec 31, 2007 | Microsoft Xbox 360 Controller
Xbox 360 Vontroller makes my audio fuzzy
same problem here. searching for a solution to this problem is like running around in circles. I'm getting to the point where I'm about to go out and buy a decent sound card and hope it works. If it doesn't I'm going to return this POS and go back to good old Logitech equipment.
Oct 24, 2007 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Controller Logo
786 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
