Question about Motorola Mobility H670 Headset
The blue light will not go steady on my H670 bluetooth
I got a new phone today... and the bluetooth worked with my older nokia but I can't get it to pair with my new phone
HI. I have a Motorola H670 Bluetooth. I've used it with two phones so far. Today I upgraded to Iphone 4. I can't get the BT to reset no matter what I do (following all instructions found). ...
Your phone will find your headset only if it is in pairing mode. This mode is denoted by its indicator light steadily lit in blue at the time you slide the call button towards the microphone (i.e. turn it on). If the light is not steadily lit then, you must ensure that all devices previously paired with your headset have their bluetooth radios turned off and try again. When the light is steady, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on the list of found devices. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is succesful, your headset should enter the stand-by mode. There might be an indication on the phone that a headset is connected too.
By the way, if your headset's user guide happens to be missing ,feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 16, 2011 | Motorola Mobility H670 Headset
How do i pair motorola h670 with blackberry torch
Please kindly follow the detailed solution provided below;
STEP 1 Put on the motorola h670 by pressing and holding the switch button for 5secs,afterwards you will hear a click followed by a blinking of blue lights,by now the headset is in pairing mode.
STEP 2 Activate the bluetooth radio on your blackberry torch,by clicking on the menu>set up>bluetooth>search.
STEP 3. After searching,your torch will find the motorola h670 in the list of found devices.click on it,afterwards a message will display saying "pairing complete".
By now your blackberry torch has been successfully paired with your motorola h670 headset and you are good to go.
Take care!
Dec 05, 2010 | RIM BlackBerry Torch Cell Phone
Motorola H670 bluetooth headphone asking passcode
The passcode is 0000 (Four Zeros)
Here's the manual:
http://itemmgt.scp4me.com/ItemInstructionFile/3228_81745.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Jan 11, 2010 | Motorola Mobility H670 Wireless Headset
Lost instructions on how to sync bluetooth to new phone
If you go in to your phones menu you will find a bluetooth snyc tool. The phone should pick up the signal if the earpiece is turned on. One thing this multifunction button does NOT do is turn the unit on and off. The entire switch itself slides up and down. There are times when you simply don’t want to bother with the earpiece, change wireless headphones, or don’t want to risk accidental calls. So the slider switch is a much easier way to keep track of whether or not the H670 is on or off than waiting for a blinking blue light that may never come.
Have a great day.
Jun 29, 2009 | Motorola Mobility H670 Wireless Headset
How do I raise the volume on the Motorola Bluetooth H670?
simple raise the volume on the phone the blue tooth is paired and will go up automaticly
Apr 13, 2009 | Motorola Mobility Bluetooth Hands Free...
The blurtooth is not going into pairing mode. I was using this bluetooth (motorola h670) with another phone and I just changed the phone.
you will have to reset your bluetooth device first and then start pairing process with the new mobile.
thx
Feb 25, 2009 | Motorola Mobility H670 Headset
H670 bluetooth not working
try adding headset, select blue T. device the properties, services and check headset and apply
Apr 26, 2008 | Motorola Mobility H670 Wireless Headset
Motorola h670 bluetooth
Manual Says 0000 but it does'nt work for me. Any other ideas anyone?
Mar 14, 2008 | Motorola Mobility H670 Headset
Ditto for me, bought two online from Sam's club, gonna return 'em
Feb 25, 2008 | Motorola Mobility H670 Wireless Headset
Motorola Mobility H670 Headset Logo
119 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
