Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Water will not fill in pool pump
We are opening our pool and after priming the pump, the water will at first go quickly through and it then the stream will trickle. It will not get to go through the filter.
  • 110 Answers
Main filter blocked (try backwashing) or if using "earth" filter system - wash filters - change earth.
Posted on Jul 07, 2009
How do you prime it?
Hi Tom:
Priming is essentially the action of getting the air out so that the pump can push water. Sometimes there is a plug at the top of the pump. If you remove it, either air and then water will come out, or nothing comes out and you can see no water inside. Fill it with water, put the plug back in, and it should work. If the pump is higher than the water level in the pool you will have a bigger task.
We'll cross that bridge if we need to.
Apr 09, 2015 | Pool & Spa
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
PINNACLE POOL PUMP SHUT OF DUE TO POWER LOSS THEN CAME BACK ON ALSO IMMEDIATELY NOW PUMP RUNS BUT NO WARE PUMPING
Fill the pump pot with water and make sure the lid o-ring is lubed and in good condition. Replace the lid and turn the pump on. If it still won't prime make sure the water in the pool is high enough. Otherwise you make have a suction side leak. Any breech in the plumbing will allow air to enter the water stream. If the breech is big enough no water will be drawn to the pump.
Oct 18, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
My pump is not drawing water from the pool, dissambeled pump and it is clean and free of obstructions. removed pump from motor and inpeller is spinning when plugged in and the defuser seems to be ok...
Ok I''m assuming the pump is mounted higher than the water level in the pool. This means it needs to be primed. If everything is air tight, it should be self priming. Check to be sure your piping is open from the skimmer to the pump and not clogged. You can put a garden hose into the suction line of the pump and feel for flow coming up out of the bottom of the skimmer. If that is ok, then fill the pump strainer basket with water. Be sure filter is selected to filter. Make sure that the basket cover is tight to the cover gasket. After filling basket with water, quickly close the cover and start pump. If it still doesn't work, fill the basket again with water and check for any leaks. If the mechanical seal is leaking, it will not self prime. I'm not sure what type of pump you have, but Hayward has complete manuals for their pumps on www.haywardnet.com. Most pumps work about the same. GOOD LUCK!
Aug 02, 2010 | Pool & Spa
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Lost prime
Turn off the pump at the timer and remove the lid to your pump where you empty the debris from the basket. Get a hose or bucket and fill that resevoir with water and get the lid back on as quickly as possible. Turn on the pump and it should start to prime. On the filter, there is a air relief valve. Depending on the filter, it will pinch and twist, or there is a knob to uncrew. Doing that as the motor is running allows tbhe air that has built up inside to puge out. Once a steady stream comes out close the relief valve. May need to tryh it more than once.
Nov 12, 2008 | Intex 2500 Gallon Sand N Sun Pool...
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
230 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
