Question about SanDisk Sansa e250 MP3 Player
PLS HELP ...
Whenever I try to put my usb setting to MSC it always restarts pks help!!
  • 626 Answers
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 24, 2007
Hi! i bought a a4tech pks-732g webcam, but its not working with my windows7 ultimate. is this a compatibility issue? pls help!
Try to search for updated drivers (device manager of Windows) directly from manager or in google. If the problem is due to drivers Device manager will show a red triangle with exclamation mark.
Sep 22, 2011 | Computers & Internet
Enter usb2.0 msd mode - pls help
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode.... make sure your usb 2.0 driver is installed....... Connect to the mother board.. MSC is best create a music1 folder and put music in there then there is no switching back and forth to mtp ms....MSC can sync the player and the expansion card
Dec 19, 2010 | SanDisk Sansa e260 MP3 Player
Low volume on sony nwz-e453 mp3
Here is the combination for the servicemenu: Back 1,5seconds Hold ON Right Left Volume UP Volume Down Right Left Option Back Option Back
Now it should restart, then set Hold to Off. Under Audio you can change the settings.
Remember to be careful.
Nov 24, 2010 | Sony Audio Players & Recorders
I need help on my Sansa e250, if I plug it to a computer or if i charge and even just merely turning it on, it just turn's on and off, my cousin who gave me my sansa told me that the battery was just...
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery and put the back on.
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music2_bing.gif folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installedMSC is best reate a music1 folder and put music in there then there is no switching back and forth to mtp msc
Apr 06, 2010 | SanDisk Sansa e250 MP3 Player
Scanned image is blank, although the page inside the scanner has text &/or picture.
Scanner contains Unlock botton below it, just unlock it it will scan fine.
Vikrant
May 08, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
"Scan To" location empty
Please follow these steps :-
1- try to scan the image in MS paint.
just open mspaint by the RUN command.
click on FILE and select FROM SCANNER AND CAMERA
then try to scan.
2- Try to restart the scanner service from the services.msc
restart the system.
or
try to restart the system in safe mode then try again to scan the document.
press F8 for safe mode while reboot the system.
3- Try to delete scanner from the DEVMGMT.MSC
just click on scanner in the list and delete that.
it can be in USB list.
restart the system
or
4- Try to uninstall scanner's driver from the DEVMGMT.MSC
just type DEVMGMT.MSC in RUN command
then select the scanner from the USB device and right click on the scanner and try to uninstall driver.
then install driver from the cd or internet.
Thanks for choosing fixya.com
May 06, 2009 | HP Scanjet G3010 Flatbed Scanner
My sandisk sansa device does not start in my computer
Here are a few things you can check:
1. Try different USB ports 2. Check the USB mode on device (Menu --> Settings --> USB mode: Auto Detect/MTP/ MSC) Try interchanging them. 3. Try restarting your PC 4. Try powercycling your mp3 player.
Jan 23, 2009 | SanDisk Sansa m240 MP3 Player
How to reformat motorola v3
always hung up whenever i write a message...
what shall i do?
pls. help me...
Oct 10, 2008 | Motorola Mobility RAZR V3
My Sansa e260 MP3 player is not working properly.
try changing to msc mode. go to settings and then usb mode
it has to be on msc mode to show up as a removable hardware
Jun 30, 2008 | SanDisk Sansa e260 MP3 Player
Sansa Scandisk e205 refresh Database failed help plz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay, heres wut u can try. try to switch the USB mode from MTP to MSC (in settings, go to USB Mode and switch from MTP to MSC.) And then in the MSC mode connect it to the PC. I dunno bout ur sansa, but my did a Database Reboot, and the computor could see the player. Then u can switch it back to the MTP mode (czu its much mroe comfortable). Although i think the 0.5 gigs are lost forever (i lost 1.5 gigs,)atleast now u can dwonlaod songs on ur player.
Sep 28, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
