Question about Kenmore Dryers
Dryer wont start
My dryer wont start, checked voltage. Getting enough. What next
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 03, 2009
Have a Maytag electric dryer, model # HYE3657AYW, stopped working all of the sudden. doesn't do anything when I set the timer and push to activate. I checked the voltage at the plug, and at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | Maytag Dryers
Dryer is not getting power but circuit breaker is
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Also this tip will help you check the power at the back of the dryer..
Check the instructions in the last paragraph for checking voltage at the dryer...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Apr 07, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
I replaced the igniter and thermal fuse and dryer
The thermal fuse should only be replaced if the dryer will not start
If it starts the thermal fuse is good.
If you touched the ignitor with your fingers it may have blown out.
Open the dryer and check for voltage to the ignitor through the ignitor wires while the dryer is on.
If you have no voltage check the hi-limit thermostat for continuity as well as the operating thermostat.
Check the flame sensor for continuity while it is cold.
If you have power to the ignitor place a clamp on amp meter on one ignitor wire and turn the dryer on.
If you read 3 amps or less the ignitor is bad.
If it reads the amps or more the gas valve coils are bad.
Jan 17, 2010 | Whirlpool Dryers
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
Dryer spins and blows out air, but no heat comes out. I had an old dryer before, and I replaced it with a fairly newer model and still, no heat is coming out of the dryer. I heard that it may be an...
Check connections at dryer terminal. sometimes they will melt and have now power and wont cause a breaker trip. plug needs 120v at L1 and 120 at L2 and equals 240 with L1 and L2 combined. can check at outlet with a meter.
Jun 08, 2009 | Maytag HYE3658AY Electric Dryer
Kenmore 90 series model 110 60902990 wont heat blows cold air
There are a few things you can check. You will need a voltage/ ohms meter. First thing you should check is that you are getting 240 Volts too the dryer. If the dryer is getting voltage, then you will need to check the heating element first. Remove the lower front panel usually held on by 2 1/4" screws. The element is located on the right side of the dryer (Looking at the front). Unplug the dryer, check continuity on the 2 terminals on the element, if there is continuity, the element is ok. Next you will need to start checking the thermostats. There is one thermostat and one safety stat on the side of the element housing. Both of those should have continuity also. If all three os those parts are checking out ok, you wil need to check the safety attached to the blower duct work directly below the drum. The easiest way to get to that safety is to remove the lint screen duct.Two 1/4" screws hold that on.
These are the most probably causes of your dryer not heating. Please contact me if you need more info.
If this helps you and you need to order the defective part, let me know and I can ship you the part also.
Hope this helps.
Vic
May 08, 2009 | Dryers
Clothes dryer won't run or start
Keep going. Voltage at the switch ? Voltage coming from the switch?None out then switch is bad.Voltage at the motor but not running? Motor is bad, Etc.
Feb 14, 2009 | Maytag Clothes Dryer Almond Timer Knob...
The Dryer wont start.
Often the main wiring connection from the house at the dryer burns, and the connection breaks. Verify the connection at the back of dryer, and if visually you can't she the brake then check for voltage (240). If there is not enough voltage at the terminal block-replace the terminal block and the cable.
Jul 28, 2008 | Whirlpool LER5636P Electric Dryer
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
Dryers Logo
124 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
