Question about Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue PC Notebook
Touch pad connections is worn out and destroyed where do you buy them m I could not find any of them googling? any one who have that part?
  • mular65 Jun 03, 2009
    Toshiba L355d- if notflat wiring I can buy the touch pad mouse complete set but could not find all over the web using searching engine. Any help
  • myshelasia
    myshelasia May 11, 2010
    What exact modsel number is it?
Can you replace the plastic cover on touch pad? One button is worn out.
The touch pad is not avail separatley, the conplete Facade/Escutcheon needs to be replaced. Part# 61005386 approx $160.00. In some cases the original clear plastic protective film might still be left on the front of the facade. Pleazer Appliance...
May 14, 2014 | Maytag MZD2766GES Side by Side...
My wipro BM49XX touch pad is not working how to solve
If the touch pad is not working I would recommend buying a mouse that can be connected via a usb port. Mouses of this sort can be found as cheap as 1$
Nov 05, 2013 | Computers & Internet
Mouse pad cursor works but cannot click
my laptop pad is not working the cursor is moving but not clicking on anything ......now wot can i do ???
Feb 11, 2012 | HEWLETT-PACKARD Computers & Internet
The cursor of my toshiba satellite has gone out of control .
You can try reinstalling the driver. I'm not sure how old your computer is or how much use it's had, it could be that the touch pad is worn out and needs to be replaced. You could try using a plug in mouse or track ball. Track balls work better with a laptop and are more like using a touch pad.
Mar 25, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Touch pad stoppedc working
reload the drivers for your touch pad,,either from the driver disc that came with your computer or from acer website. or google aspire 5050 3242 drivers, be sure to download driver for the correct version of windows you are running. Good luck
Feb 04, 2010 | Acer Aspire 5050-3242 Notebook
The mouse pad on my Acer Aspire 5315-2713 is no longer working. I've had the notebook aprox. 1.5 years. What can I do?
Make sure the mouse pad is enabled. Check the manual or web site for your model. Generally, the mouse pad (and other functions) can be accessed by pressing the Fn key + a specific F_ key (1-12).
Sometimes this device or others can accidentally be disabled.
Dec 06, 2009 | Acer Aspire 5315 Notebook
Screen problem
hi..... this is the only way with the touch screens
  • If the touch pad is scratch or cracked , you can replace the touch screen(touch pad/Digitizer) only.
  • The touch screen have the protect film on it,please remove the protect film before you use the touch screen .
  • Before you buy this item please check your touch screen model and make sure it's same as the photo.
  • 100% brand new.
Jul 15, 2009 | O2 Xda Atom
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue  PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
