Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Chevy starter ignition
1995 chevy K1500 truck will not shut off have to stall
    Scholar:
  • 108 Answers
This isn't a solution but it should help. Pull the column off and see what color the wires are that go to the ignition switch. Next look under the dash and find the connector that has these wires. Start the truck, reach under the dash and pull the connector apart and see if it dies. If it doesn't then consider the ECM relay is sticking. If it dies when you pull the connector apart, then your ignition switch could be back and is shorting the constant hot to the ignition out allowing the truck to keep running. You can also try pulling the ECM relay when its running and see if it dies. If it does then switch it with another relay, like the headlights if they use the same style relay and turn the headlights on then off and see if they stay on, alone with starting the truck and running it for a period of time then shutting it off and see if it dies or not. Post a comment and let me know if either of these has an effect.
Posted on Jul 15, 2009
My 93 Chevy Suburban k1500 stalls when going through puddles and will not start back up right away. It turns over very.slow after it stalls.
Sounds like exposed wiring possibly on the ignition coil or alternater simillar issues happen when weather pack connectors on vital sensors leak causing the sensors to malfuntion most likely exposed wires though since its not getting solid power to the starter after the stall
Jan 05, 2012 | 1993 Chevrolet Suburban
1995 chevy truck k1500 with an electrical problem. Just shuts off, engine, lights, etc. Starter ok. Any ideas?
check to make sure your passenager upper shock mount didnt break and shew up your primary battery wire had that problem a week ago
Dec 04, 2010 | 1995 Chevrolet K1500
L already put new battery ,fuse and starter to my chevy 1995 silverado but how come it wont start if I turn on the ignition.
you might have a bad connection or bad wires bad ground the first thing you have to do is see if you are getting 12 volts to the thick red wire on the starter then when someone is turning the key the small red or purple wire should get 12 volt
Nov 10, 2010 | 1995 Chevrolet K1500
Where is the ignition module on a 1998 chevorlet pickup k1500 5.7l?
where is the ignition module on a 1998 chevrolet pick-up truck k2500
Jul 18, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
What are the symptoms of a faulty ignition switch on a 1995 GMC 1500 truck
stalling. failure to start. no electrical current to lights in dash. no electrical current to fuel pump
Feb 13, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
1997 k1500 chevy 4x4 5.7
You have to check when the engine is stopped if it is missing spark or fuel because the engine is stopped for lack of spark or fuel to be able to verify that a better diagnosis. Thank you
Aug 01, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
236 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
