Question about Taylor Leo Kottke Signature Model Guitar Acoustic
Strings slip The strings slip often, causing it to need retuning - happens within 10 minutes of playing (at least 1 string goes out of tune). Strings also slip while tuning - need to turn a peg more than 5 or so degrees before pitch changes (and it overshoots). Taylor installed a new nut. Still busted. Any ideas? Thanks, Sol
    Top Expert:
  • Taylor Master
  • 28,460 Answers
That is a discontinued model.
Check which way it is losing tuning. If from the machine heads, very unusual, try an extra turn on the tuning bar. If the string is slipping at the bridge end, check the fitting of the strings.
If you make a mark with a felt tip pen on the 12th fret position on the string, see which way it moves.
Posted on Dec 07, 2017
Tune Guitar strings 1,2 & 3 to Banjo and play with finger pickers. Bass strings to accompany. Developed complicated chords (Including Bass strings) I need to record this on paper - any tips?
Are you familiar with Tablature notation. It's instrument specific and instead od a regular staff you maje a duagram od the instruments strings looking down on the neck and then instead of notes the number of the fret goes on the relevant 'string'
https://www.guitartricks.com/helptab.php
and it's similar for banjo. Google tablature explained and a page comes up with a selection of instrument tabs.
Sep 15, 2017 | Bass Music
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
What is the proper way to change a string on a guitar so it doesn't slip?
The first thing to remember is that the strings will stretch so i always over tune it about a turn for small strings and 3 for the big strings. To prevent it from slipping when you are tightening the string pull it tight while turning it and make sure the string has overlapped its self a couple times before releasing it.
Apr 08, 2012 | Fender Music
I bought a used Fender FB55 banjo, it's appearance looks new. I'm new to banjo's but not guitars. I really didn't know how a banjo should sound. I practiced with it as is, I noticed that I...
Check the neck to body attachment. There may be a problem there, especially if it has been strained in the past. The fact that the strings were so high when you got this would indicate there MAY be a problem with the neck attachment or the body where it attaches. Word of caution: Investigate how repairs are done on the instrument before attempting a fix. Using wrong materials can permanently disable an instrument. Banjos DO go out of tune easily, depending on how they are played. Another thing to remember is that strings are within about 10% of breaking when in tune on stringed instruments.
Sep 10, 2011 | Fender FB55 5-String Banjo (Refurbished)
How do you change your chord set-up on an autoharp and is there any reason not to set it up like a piano keyboard (C-D-E-F-G-A-B)? Thanks in advance.
An autoharp makes chords by muting all the strings except those that make the chord. There would be 2 ways to change the chord structure. 1) retune the strings knowing which ones will be muted by each key so that the result is another but valid chord or 2) make your own "keys" so that they mute different strings.
The tuning of an autoharp is selected to allow you to play songs as long as they are in the right key or two. If you set it "like a piano" as you suggest, you could play those chords but not the chord sequences that make up most songs. Most songs revolve around sequences or intervals such as the popular 1 - 4 - 5 blues progressions. Most music has some predictable progressions and that's why the autoharp is tuned the way it is.
You can always experiment with different and odd tunings but if your goal is to play already written songs, I'd stick with the normal tunings - there are alternates.
Jan 29, 2011 | Oscar Schmidt Autoharp
When i lock the tuning locks the guitar is out of tune within 3-5 minutes of locking, then when i try to re tune it the strings snap. whats the problem?
I am not familiar with your model of guitar, but I assume it has a tremelo system. Usually when a string breaks at the nut like that, it's because the metal piece that locks the string is not smooth, has a burr on it. It could also be that the lock is holding just well enough that when you bend a string it is slipping some but doesn't go back all the way. Try just totally unlocking it and playing a bit to see what happens. The friction may be wearing on the string where it contacts the lock. I am assuming it is breaking near the nut/lock area, is that right? Or is it breaking at the bridge end?
Jan 14, 2011 | Schecter Synyster Standard Electric Guitar
I just got this guitar. I pull the tuner control, strum the string and after the guitar tune itself, the G string still out of tune??
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Feb 05, 2010 | Gibson Robot SG Special LTD Ebony
Gibson Les Paul wont stay in tune
That's the problem; you're using light gauge guitar strings. Chances are that if you are not used to playing strings that light, you're fretting hand will hit the strings with more force than is neccesary to fret them, thereby forcing them out of tune. You can solve this problem by adding more winds around the string post (three or more winds should do it), or you can switch to a heavier gauge of string.
If they're true locking tuners, they should have a notch on the back of the gear housing that you turn with a nickel to engage the locking mechanism once tuning has been established.
Also; check the intonation of the guitar itself on an electronic tuner. If it tunes right but sounds out of tune when played, this is an intonation issue, and can be solved by adjusting a small set screw that moves the individual saddle back and forth in the tune-o-matic style bridge. You can check this by tuning the string to the correct note, then playing the same string at the 12th fret and checking it against your tuner. If it rings in true, you're fine, if it comes up flat or sharp, every note on the fretboard is going to be off by that much, and you'll have to adjust accordingly (turn the screw to the right to add length and lower a sharp note, turn the screw to the left to subtract length and raise a flat note, if I remember right).
Hope that helps.
May 12, 2009 | Gibson Music
My Dean razorback V Standard keeps going out of tune and I have no clue how to fix it.
First, I don't know how long you've been playing guitar but you need to make sure the strings aren't old and/or not kept clean. The oils and skin cells from our fingers will cause strings to break down in there elasticity, therefore causing them to lose there retention (eg. memory). If you have a locking system with floating bridge then make sure your locks are tight, but not to tight as to strip or break the screws. Next, if you have a cheaper guitar, like in the $250 range, you will experience this more often than not, especially if you don't have a locking system. But just remember that guitars have to be retuned all the time (just watch live video of guitarists like Jimmy Page and Angus Young, etc.) if you play a lot and really play the instrument to the fullest (eg. Dive Bombs, EVH Horsie, Pitch Bends, etc.). Also, when you put on new strings they need time to stretch before they find that place where they retain their memory so it's a good idea to play and stretch the strings using various techniques like bending and whammy (EVH has been known to boil his strings to aid in this). Last, but not quite the least, if you find your guitar going out of tune after just a few minutes and after all my suggestions then your guitar may have a problem with its INTONATION, which you'll need to take it to a guitar technician which won't cost much and you'll be very happy with the sound. One last thing to remember, if you have a cheaper guitar without locking system they're really not capable or designed for using the whammy bar that comes with most of them---this is just a feature for helping to sell the guitar because everyone wants a whammy bar---the guitar will go considerably out of tune everytime it's used. Hope this long explanation helps.
Dec 09, 2008 | Dean Razorback Db Electric Guitar
Taylor Leo Kottke Signature Model Guitar Acoustic Logo
19 people viewed this question
Top Taylor Music Experts
Christoverre Kohler
Christoverre Kohler
rhodesworks
Christopher White
Level 1 Expert
Are you a Taylor Music Expert? Answer questions, earn points and help others
